.load file
The .load file is an OptiStruct ASCII format results file.
File Creation
Creation of this file is controlled by the OLOAD I/O Option.
File Contents
Result | Description |
Applied Load | Applied load vectors for linear static analysis. |
File Format
The applied load file has the following format:
For each iteration, the following header is used: | |||||||||||
iter | Iteration | NumIds |
- Data
- Description
- iter
- Keyword denoting the beginning of a new iteration.
- Iteration
- Iteration number.
- NumIds
- Number of subcases for which this output is created.
Each iteration section is divided up by subcase. Output for each subcase starts with
a line in the following format:
Id | Number_of_nodes | Frequency | LOAD: Spc_id(Datatype) | subcase_label |
- Data
- Description
- Id
- Output identification number for the subcase. This is not the same as the subcase ID used in the input data.
- Number_of_nodes
- Number of nodes for which this output is requested.
- Frequency
- Is 1.0 for static analysis.
- LOAD
- Keyword declaring applied load information.
- Spc_id
- SID for SPC's referenced by this subcase.
- Datatype
- Keyword indicating the type of subcase involved.
The following information is then provided for each node, for which this output was
requested:
NID | X force | Y force | Z force | X mom | Y mom | Z mom |
- Data
- Description
- NID
- Node identification number.
- X force
- X force at the node.
- Y force
- Y force at the node.
- Z force
- Z force at the node.
- X mom
- X moment at the node.
- Y mom
- Y moment at the node.
- Z mom
- Z moment at the node.
- The I/O Option Previously Supported Results controls the frequency of output for analytical results during an optimization.
