Loading [MathJax]/jax/output/CommonHTML/jax.js
MATF
Bulk Data Entry Defines material properties and failure model parameters for Failure criteria calculations.
MATF MID
  CRI CRITERIA TID/V1 V2 V3 V4 V5 V6
  V7 V8 V9         W1
  W2 W3
  etc
MATF 100
  CRI PUCK 3.E5 3.E5 3.E5 3.E5 3.E5
                0.25
  0.25 0.25
MID Material identification number.
(Integer > 0)
CRI CRI flag indicating that the failure criterion input data are to follow. 8
CRITERIA Character String representing the chosen failure criterion.
PUCK
Puck failure criterion.
HILL
Hill failure criterion.
HOFF
Hoffman failure criterion.
TSAI
Tsai-Wu failure criterion.
HASH
Hashin failure criterion.
STRN
Maximum strain failure criterion.
DUCTILE
Damage initiation criterion.
PUCK3D
Puck failure criterion for continuum shell elements.
HILL3D
Hill failure criterion for continuum shell elements/solid elements with anisotropic material.
HOFF3D
Hoffman failure criterion for continuum shell elements/solid elements with anisotropic material.
TSAI3D
Tsai-Wu Failure criterion for continuum shell elements/solid elements with anisotropic material.
HASH3D
Hashin failure criterion for continuum shell elements.
STRND3D
Maximum strain failure criterion for continuum shell elements/solid elements with anisotropic material.
STRS3D
Maximum stress failure criterion for continuum shell elements/solid elements with anisotropic material.
CNTZ3D
Cuntze failure criterion for continuum shell elements.
No default
TID Identification number of a TABLEMD entry that identifies the equivalent plastic strain (Yi) at the onset of damage vs temperature (Xi). 6
Vi Material stress limits.
V1
Tensile stress limit in longitudinal direction.
V2
Compressive stress limit in longitudinal direction.
V3
Tensile stress limit in lateral direction.
V4
Compressive stress limit in lateral direction.
V5
In-plane shear stress limit.
(Real > 0.0)
Wi Parameters for failure criteria calculations.
W1
Failure envelope factor 12(-).
W2
Failure envelope factor 12(+)
If blank, set to be equal to W1, W1 and W3 should be specified.
W3
Failure envelope factor 22(-).
(Real > 0.0)
  1. MID field may refer to MAT1, MAT2, MAT8, MAT9 or MAT9ORT entries.
  2. For laminated shells (PCOMP/PCOMPP/PCOMPG).
    V1, V2, through V5 specify material stress limits.
    V1
    V2
    V3
    V4
    V5
    For Solid Elements (MAT9/MAT9OR) and Continuum Shells (PCOMPLS).
    V1, V2 through V9 specify material stress limits.
    V1
    Tensile stress limit in 1-1 direction
    V2
    Compressive stress limit in 1-1 direction
    V3
    Tensile stress limit in 2-2 direction
    V4
    Compressive stress limit in 2-2 direction
    V5
    Tensile stress limit in 3-3 direction
    V6
    Compressive stress limit in 3-3 direction
    V7
    Shear stress limit in 1-2 direction
    V8
    Shear stress limit in 2-3 direction
    V9
    Shear stress limit in 1-3 direction
    Coordinate system 1-2-3 are user-defined for continuum shell elements or solid elements with MAT9.
  3. W1, W2 and W3 definition is dependent on the failure criterion specified.
    • PUCK/PUCK3D specify failure envelope parameters:
      W1
      W2
      If W2 is blank, it is set to be equal to W1, W1 and W3 should be specified.
      W3
    • TSAI3D on anisotropic solid material
      They are the tensile stress limits in equal-biaxial tension tests. W1 is the tensile stress limit in equal-biaxial tests where the two tensile loads are in directions 1 and 2. W1 is mandatory, while W2 and W3 are optional. If W2 and W3 are not specified, then they are set equal to W1. The definition of W2 and W3 is similar to W1. W2 is the tensile stress limit in equal-biaxial tension tests where the two tensile loads are in directions 2 and 3. W3 is the tensile stress limit in equal-biaxial tension tests where the two tensile loads are in directions 1 and 3.
    • HASH3D
      When Hashin failure criteria is applied on continuum shell elements, W1 is defined as alpha, which takes the transverse shear stress (in 1-2 and 1-3 direction) into account in the tensile fiber check. When W1 is blank, alpha is assumed to be 1.0.
    • CNTZ3D
      When using Cuntze failure criterion, W1, W2, and W3, corresponding to the three free curve parameters,  b|| , bT  and bτ|| should be provided. The free curve parameters can be determined from multi-axial test data from experiments. Bounds on the safe side for GFRP, CFRP and AFRP are assumed by Cuntze 1 to be:(1)
      0.0.5<b||<0.15,1.0<bT|<1.6,0<bτ||<0.4
  4. Different failure criteria for different materials can be defined by referencing the corresponding material entry (with same ID as MATF) on MID# fields of the PCOMP and PLY entries (for PCOMPP). If different materials with different failure criteria are required to be defined for a single composite property, then MATF entry should be used.
  5. The following criteria can only be defined on the MATF entry.
    PUCK, DUCTILE, PUCK3D, HILL3D, HOFF3D, TSAI3D, HASH3D, STRN3D, and CNTZ3D.
    The rest of the criteria can also be defined on the FT field of the corresponding PCOMPP/PCOMPG/PCOMP entry.
    For the PUCK failure criterion, even though it is available on the FT field of the PCOMPP/PCOMPG/PCOMP entry, the corresponding failure envelope factors (W1, W2, W3) can only be defined on the MATF entry. Therefore, the MATF entry is mandatory when PUCK failure criterion is requested via the FT field of PCOMP/PCOMPG/PCOMPP entries, and additionally, the allowables should be defined on the MATF for PUCK criterion only. To use PUCK failure criteria, the MATF entry should be specified with MID referring to the corresponding material entry.
  6. If the CRITERIA field is set to DUCTILE, then the TID field should point to a TABLEMD entry with NDEP set to 1. The first data column (Yi) is the equivalent plastic strain at the onset of damage. The second data column (Xi) is the corresponding temperature. The second column should be specified in ascending order only.
    When the CRITERIA field is set to DUCTILE in OSTTS analysis, the temperature-based lookup is conducted for each temperature to identify the corresponding equivalent plastic strain from the TABLEMD entry. This plastic strain is used in conjunction with the calculated von Mises Strain to calculate Damage (This can be output using the DAMAGE I/O Options Entry).
  7. The following tables summarize the supported failure criteria with different properties and materials.
    Table 1. Shell Elements
      PSHELL PCOMP/PCOMPG/PCOMPP
      MAT1/MAT2/MAT8
    HILL No Yes
    HOFF No Yes
    TSAI No Yes
    STRN No Yes
    HASHIN No Yes
    PUCK No Yes
    DUCTILE No Yes
    Table 2. Solid Elements
    PSOLID PCOMPLS
    MAT9 MAT9OR MAT9 MAT9OR
    HILL3D Yes Yes Yes Yes
    HOFF3D Yes Yes Yes Yes
    TSAI3D Yes Yes Yes Yes
    STRN3D Yes Yes Yes Yes
    STRS3D Yes Yes Yes Yes
    HASH3D No Yes Yes Yes
    PUCH3D No Yes Yes Yes
    CNTZ3D No Yes Yes Yes
  8. Multiple different failure criteria can be defined on a single MATF entry. Therefore, the CRI continuation line can be repeated, and multiple different failure criteria can be specified. However, a particular failure criterion can only appear once on the MATF entry, and cannot be repeated.
1 Cuntze, R.G. and Freund, A., The predictive capability of failure mode concept-based strength criteria for multidirectional laminates in Failure Criteria in Fibre Reinforced Polymer Composites, 2004 QinetiQ Ltd. Published by Elsevier Ltd.
