MATX02
Bulk Data Entry Defines additional material properties for Johnson-Cooke elastic-plastic material for geometric nonlinear analysis. This is an elasto-plastic law with strain rate and temperature effects.
MATX02 MID A B N EPSMAX SIGMAX C DEPS0
  ICC FSMOOTH F M T RCP
MAT1 102 60.4   0.33 2.70E-06
MATX02 102 0.09026 0.22313 0.374618 100.0 0.175
MID Material ID of the associated MAT1. 1
No default (Integer > 0)
A Plasticity yield stress.
(Real > 0)
B Plasticity hardening parameter.
(Real ≥ 0)
N Plasticity hardening exponent.
Default = 1.0 (Real ≤ 1.0)
EPSMAX Failure plastic strain εε εmaxεmax
Default = 1030 (Real > 0)
SIGMAX Maximum plastic stress σmax0σmax0
C Strain rate coefficient. If zero, there is no strain rate effect.
Default = 0.0 (Real)
DEPS0 Reference strain rate ˙ε0˙ε0 .
If DESPSDESPS0, no strain rate effect.
ICC Strain rate dependency of σmax0σmax0 flag. 5
OFF
ON (Default)
FSMOOTH Strain rate smoothing flag.
OFF (Default)
ON
F Cutoff frequency for strain rate filtering. Only for shell and solid elements.
Default = 1030 (Real ≥ 0)
M Temperature exponent.
T Melting temperature.
RCP Specific heat per unit of volume.
Default = 0.0 (Real ≥ 0)
  1. The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT1.
  2. MATX02 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS=EXPDYN. It is ignored for all other subcases.
  3. This is an elastic-plastic law with strain rate and thermal effects. It follows:(1)
    σ=(a+bεnp)(1+cIn˙ε˙ε0)(1T*m)σ=(a+bεnp)(1+cIn˙ε˙ε0)(1Tm)
    Where,(2)
    T*=TT0TmeltT0T*=TT0TmeltT0
    Where,
    εpεp
    Plastic strain
    ˙ε˙ε
    Strain rate
    TT
    Temperature (in Kelvin)
  4. If the plastic strain reaches EPSMAX, shell elements are deleted. Solid elements are not deleted, but the deviatoric stress is set to zero.
  5. ICC controls the strain rate effect.
    σ=σy(1+cIn(˙ε˙ε0))σmax=σmax0(1+cIn˙ε˙ε0)
  6. No strain rate effects are considered in rod elements.
  7. Strain rate filtering is used to smooth strain rates. The input F is available only for shell and solid elements.
  8. To take into account the temperature effect, strain rate dependence must be activated. If the temperature exponent M=0; there is no temperature effect. No temperature effect is considered on rod, bar, and beam elements.
  9. The temperature is computed assuming adiabatic conditions:(3)
    T=Ti+EintρCp(Volume)
    Where, E is the internal energy.
    If ρCp = 0, the temperature is constant T=Ti .
  10. This card is represented as an extension to a MAT1 material in HyperMesh.
