MATX36
Bulk Data Entry Defines additional material properties for piece-wise linear elastic-plastic material for geometric nonlinear analysis.
MATX36 | MID | EPSMAX | EPST1 | EPST2 | EPSF | FSMOOTH | F | ICH | |
TPID | PSCA | ||||||||
TID1 | FSCA1 | EPSR1 | |||||||
etc | etc | etc | |||||||
TIDi | FSCAi | EPSRi |
MAT1 | 102 | 60.4 | 0.33 | 2.70E-06 | |||||
MATX36 | 102 | ||||||||
10 | 1.0 | ||||||||
7 | 1.0 | 0.0 |
MID | Material identifier of the
associated MAT1. 1 No default (Integer > 0) |
EPSMAX | Failure plastic strain
εmaxεmax
. Default = 1030 (Real > 0) |
EPST1 | Maximum tensile failure
strain. 5 Default = 1030 (Real > 0) |
EPST2 | Maximum tensile failure
damage. 6 Default = 2.0*1030 (Real > 0) |
EPSF | Tensile strain for element
deletion. Default = 3.0*1030 (Real > 0) |
FSMOOTH | Strain rate smoothing
flag.
F | Cutoff frequency for
strain rate filtering. Only for shell and solid elements. Default = 1030 (Real ≥ 0) |
ICH | Hardening coefficient.
(Real > 0) |
TPID | Identification number of a
TABLES1 that defines pressure dependent yield
stress function. No default (Integer > 0) |
PSCA | Scale factor for stress in
pressure dependent function. Default = 1.0 (Real) |
TIDi | Identification number of a
TABLES1 that defines the yield stress vs.
plastic strain function corresponding to EPSRi.
Separate functions must be defined for different strain rates. No default (Integer > 0) |
FSCAi | Scale factor for
TIDi. Default = 1.0 (Real) |
EPSRi | Strain rate. Strain rate
values must be given strictly in ascending
order. (Real) |
- The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT1.
- MATX36 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS=EXPDYN. It is ignored for all other subcases.
- The first point of yield stress functions (plastic strain vs. stress) should have a plastic strain value of zero. If the last point of the first (static) function equals 0 in stress, the default value of EPSMAX is set to the value of the corresponding plastic strain.
- When the plastic strain reaches EPSMAX, the element is deleted.
- If the first principal strain
ε1ε1
reaches
εε
t1 = EPST1, the stress
σσ
is reduced by:
(1) with εε t2 = EPST2.σ=σ(εt2−ε1εt2−εt1)σ=σ(εt2−ε1εt2−εt1) - If the first principal strain ε1ε1 reaches εε t2 = EPST2, the stress is reduced to 0 (but the element is not deleted).
- If the first principal strain ε1ε1 reaches εε f = EPSF, the element is deleted.
- Strain rate filtering is used to smooth strain rates. The input F is available only for shell and solid elements.
- Hardening is defined by
ICH.
Figure 1. - The kinematic hardening model is not available with global formulation (NIP=0 on PSHELX), that is hardening is fully isotropic.
- In case of kinematic hardening and strain rate dependency, the yield stress depends on the strain rate.
- TPID is used to distinguish the behavior in tension and compression for certain materials (that is pressure dependent yield). This is available for both shell and solid elements. The effective yield stress is then obtained by multiplying the nominal yield stress by the yield factor PSCA corresponding to the actual pressure.
- The first function TID1 is used for strain rate values from 0 to the corresponding strain rate EPSR1. However, the last function used in the model does not extend to the maximum strain rate; for higher strain rates, a linear extrapolation will be applied. Hence, if ˙ε0˙ε0 ≤ EPSRi, the yield stress is interpolated between TIDi and TIDi-1. If ˙ε0˙ε0 ≤ EPSR1, TID1 is used. Above EPSRAX the yield stress is extrapolated.
- Strain rate values must be given strictly in ascending order. Separate functions must be defined for different strain rates.
- At least one strain rate is needed under which the yield stress vs. plastic strain function is defined.
- This card is represented as a material in HyperMesh.
