MATX44
Bulk Data Entry Defines additional material properties for Cowper-Symonds elastic-plastic material for geometric nonlinear analysis.
MATX44 MID A B N ICH SIGMAX C P
  ICC FSMOOTH F EPSMAX EPST1 EPST2
MAT1 144 0.11   0.11 9.92E-07
MATX44 144
MID Material ID of the associated MAT1.
No default (Integer > 0)
A Plasticity yield stress.
(Real > 0)
B Plasticity hardening parameter.
(Real ≥ 0)
N Plasticity hardening exponent.
Default = 1.0 (Real)
ICH Hardening coefficient.
0.0
The hardening is a full isotropic model.
1.0 (Default)
Hardening uses the kinematic Prager-Ziegler model.
Between 0.0 and 1.0
Hardening is interpolated between the two models.
(Real ≥ 0)
SIGMAX Maximum plastic stress σmax0σmax0 .
Default = 1030 (Real > 0)
C Strain rate coefficient.
Default = 0.0 (Real)
P Strain rate exponent.
ICC Strain rate dependency of σmax flag. 5
ON (Default)
OFF
FSMOOTH Strain rate smoothing flag.
OFF (Default)
ON
F Cutoff frequency for strain rate filtering.
Default = 1030 (Real ≥ 0)
EPSMAX Failure plastic strain.
EPST1 Tensile rupture strain 1.
EPST2 Tensile rupture strain 2.
Default = 2.0 * 1030 (Real > 0)
  1. The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT1.
  2. MATX44 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
  3. The Cowper-Symonds models an elastic-plastic material, only for solids and shells. The basic principle is the same as the standard Johnson-Cook model; the only difference between the two lies in the expression for strain rate effect on flow stress.
    (1)
    σ=(a+bεnp)(1+(˙εc)1p)
    with εp being plastic strain, and ˙ε being the strain rate.
  4. Hardening is defined by ICH.
  5. ICC controls the strain rate effect.
    σ=σy(1+cIn(˙ε˙ε0))σmax=σmax0(1+cIn˙ε˙ε0)
  6. No strain rate effects are considered in rod elements.
  7. Strain rate filtering is used to smooth strain rates. The input F is available only for shell and solid elements.
  8. When the plastic strain reaches EPSMAX, the element is deleted.
  9. ε if the first principal strain ε 1 reaches t1 = EPST1, the stress σ is reduced by:
    (2)
    σ=σ(εt2ε1εt2εt1)
    with ε t2 = EPST2.
  10. If the first principal strain ε 1 reaches ε t2 = EPST2, the stress is reduced to 0 (but the element is not deleted).
  11. If the first principal strain ε 1 reaches ε f = EPSF, the element is deleted.
  12. This card is represented as an extension to a MAT1 material in HyperMesh.
