NOLIN4
Bulk Data Entry Defines nonlinear transient forcing functions of the form.
Pi(t)={−S⋅[−Xj(t)]A,Xj(t)>00,Xj(t)≤0
Where, Xj(t) may be a displacement or a velocity at point GJ in the direction of CJ.
NOLIN4 | SID | GI | CI | S | GJ | CJ | A |
NOLIN4 | 2 | 4 | 6 | 2.0 | 101 | 16.3 |
SID | Nonlinear load set
GI | Grid or scalar point
identification number at which nonlinear load is to be
applied. No default (Integer > 0) |
CI | Component number for
GI. No default (1 ≤ Integer ≤ 6; blank or 0, if GI is a scalar point) |
S | Scale factor. No default (Real) |
GJ | Grid or scalar point
CJ | Component number for GJ, GK according to the following table. | |
A | Exponent of the
forcing function. No default (Real) |
Type | Displacement | Velocity |
Grid | 1 ≤ Integer ≤ 6 | 11 ≤ Integer ≤ 16 |
Scalar | Blank or 0 | Integer = 10 |
- Nonlinear loads must be selected by the Subcase Information data selector NONLINEAR.
- Nonlinear loads may not be referenced on a DLOAD entry.
- All degrees-of-freedom referenced on NOLIN4 entries must be members of the solution set.
- Nonlinear loads may be a function of
displacement
(Xj=uj)
or velocity
(Xj=˙uj)
. Velocities are denoted by components ten
greater than the actual component number; that is the component 11 indicates
velocity in the 1 component direction. The velocity is determined
by:
(2) ˙uj,t=uj,t−uj,t−1ΔtWhere,- Δt
- Time step interval
- uj,t−1
- Displacement of GJ-CJ for the previous time step.
- Use a NOLIN3 entry for the positive range of Xj(t) .
- The time step algorithm in transient solution sequences may loose unconditional stability when this load entry is used. In most practical cases, the time step size chosen to reach a certain accuracy is below the stability limit. It is recommended to decrease the time step if results diverge.
