Loading [MathJax]/jax/output/CommonHTML/jax.js
PARAM, CK2
Bulk Data Entry Scale factor for direct input stiffness matrices.
Parameter Values Description
CK2 <Real>
Default = 1.0
CK2 specifies factors for the direct input stiffness matrix. The total stiffness matrix is:
Kjj=Kxjj+CK2*K2jj
Where,
K2jj
Is selected in the Subcase Information command K2GG.
Kxjj
Is generated from structural element entries in the Bulk Data section.
