Loading [MathJax]/jax/output/CommonHTML/jax.js
PARAM, CP2
Bulk Data Entry Scale factor for direct input load matrices.
Parameter Values Description
CP2 <Real>
Default = 1.0
CP2 specifies factors for the direct input load matrix. The total load matrix is:
Pj=Pxj+CP2*P2j
Where,
P2j
Is selected in the Subcase Information command P2G.
pxj
Is generated from the static load entries in the Bulk Data section.
