PARAM, KDAMP
Bulk Data Entry Enters viscous modal damping into the stiffness matrix as structural damping.
Parameter | Values | Description |
KDAMP | <-1, 1 > |
- To achieve identical displacements in Modal frequency response or Modal
transient analyses when the SDAMPING subcase information entry is used instead of
PARAM, G, the steps described here can
be followed:
- The TYPE field in the TABDMP1 Bulk Data Entry should be set to CRIT. This TABDMP1 Bulk Data Entry is referenced by the SDAMPING Subcase Information Entry.
- Set the damping value (field gi) in the TABDMP1 Bulk Data Entry equal to half of the value of PARAM, G (that is set the constant value to C/C0 ).
- Set PARAM,KDAMP,-1 (See description above).
