RADM
Bulk Data Entry Defines the radiation material properties of a surface element for heat transfer analysis.
RADM | RMID | ABSORP | EMIS1 |
RADM | 24 | 0.2 | 1.0 |
RMID | Radiation material
property entry identification number. No default (Integer > 0) |
ABSORP | Surface
absortivity. No default (0.0 ≤ Real ≤ 1.0) |
EMIS1 | Surface emissivity.
- The RADM entry can be referenced by a CHBDYE Bulk Data Entry.
- The Radiation Heat Flux is
calculated as follows, between the surface element and the black-body space
node.
(1) Where,- Radiation heat flux.
- Stefan-Boltzmann constant defined via PARAM, SIGMA.
- Radiation view factor between the element face and the ambient space node.
- Surface emissivity of the surface element, defined by EMIS1 on the RADM entry.
- Surface absorptivity of the surface element, defined by ABSORP field on the RADM entry.
- Surface temperature.
- Absolute temperature scale factor defined via PARAM, TABS.
- Ambient temperature.
- For a Heat Transfer Analysis via Radiation, PARAM,TABS can be used to define the absolute temperature scale, and PARAM,SIGMA is used to specify the Stefan-Boltzmann constant. Additionally, a RADBC entry can be used to define radiation boundary conditions.
