The .secres file is an OptiStructASCII format results file.
File Creation
This file is created when SECTION Bulk Data Entry is present in
the model and/or 3D pretension bolts are present in the model.
File Contents
This file contains a summary SECTION coordinate systems and
Section Resultant forces and moments. In the .secres file, the
full name of the section surface used for the pretension bolt definition is also
printed.
Note: This information is also printed in the .out
file.
File Format
The following table format is used to print the initial contact summary
information. Figure 1.
Name
Content
NA
SECTION COORDINATE SYSTEMS
(XX,XY,XZ) (YX,YY,YZ) (ZX,ZY,ZZ) identify the axes of the
coordinate system and (RX,RY,RZ) identifies the reference
point
NA
Full Pretension Section Surface Name
Full name of the bolt pretension section used during the
definition of the pretension bolt.
NA
SECTION RESULTANTS FOR SUBCASE #
Lists the resultant section forces and moments for each
subcase #.
NA
