SENSOR
Bulk Data Entry Defines a sensor for geometric nonlinear analysis. Sensors may be used to activate loads (NLOAD1).
SENSOR SID STYPE DELAY NACC
Continuation lines if STYPE=ACCEL (number of continuation lines = NACC)
  AID1 DIR1 AMIN1 TMIN1
  AID2 DIR2 AMIN2 TMIN2
  etc. etc.
Continuation line if STYPE=DIST
  G1 G2 DMIN DMAX
Continuation line if STYPE=SENS, AND, OR
  SID1 SID2
Continuation line if STYPE=NOT
  SID1
Continuation line if STYPE=NTER
  CID
Continuation line if STYPE=RWAL
  RWID
SENSOR 100 ACCEL 1
  7 X 500.0 0.03
SID Unique sensor identification number.
No default (Integer > 0)
STYPE Sensor type. May be one of:
TIME
Start time - the sensor is activated after the time delay (DELAY).
ACCE
Accelerometer.
DIST
Nodal distance.
SENS
Activation with sensor SID1, deactivation with sensor SID2.
INTER
Interface activation and deactivation.
RWAL
Rigid wall activation and deactivation.
AND
ON if sensors SID1 and SID2 are ON
NOT
ON if sensor SID1 is OFF
OR
ON if sensors SID1 or SID2 is ON
No default
DELAY Time delay.
(Real > 0)
NACC Number of accelerometers ACCEL.
(0 < Integer ≤ 6)
AID# Accelerometer identifier, references the ID of an ACCLR Bulk Data Entry.
(Integer > 0)
DIR# Direction of accelerometer #. May be one of:
X
X direction
Y
Y direction
Z
Z direction
XY
XY plane (γ2x+γ2y)(γ2x+γ2y)
YZ
YZ plane (γ2y+γ2z)
ZX
ZX plane (γ2z+γ2x)
XYZ
Total acceleration (γ2x+γ2y+γ2z)
No default
AMIN# Minimum absolute value for acceleration for accelerometer #.
(Real ≥ 0)
TMIN# Minimum duration of AMIN for accelerometer #.
(Real ≥ 0)
G1 Grid ID 1.
(Integer > 0)
G2 Grid ID 2.
(Integer > 0)
DMIN Distance minimum.
(Real ≥ 0)
DMAX Distance maximum.
(Real ≥ 0)
SID1 Activation sensor identifier, references the ID of another SENSOR Bulk Data Entry.
(Integer > 0)
SID2 Deactivation sensor identifier, references the ID of another SENSOR Bulk Data Entry.
(Integer > 0)
CID Contact identifier, references the ID of a CONTACT Bulk Data Entry.
(Integer > 0)
RWID Rigid Wall identifier, references the ID of a RWALL Bulk Data Entry.
(Integer > 0)
  1. A sensor can only be activated once.
  2. For STYPE=ACCE, the sensor is activated if one of the accelerometers gives an acceleration greater than AMIN during a time greater than TMIN.
    The time of activation of the sensor is the time at which the above criteria is first met plus the time delay (DELAY).
  3. For STYPE=DIST, the sensor is activated once the distance between G1 and G2 moves outside the allowable range (between DMIN and DMAX).
    The time of activation of the sensor is the time at which the above criteria is first met, plus the time delay (DELAY).
  4. For STYPE=SENS, the sensor is activated once the referenced sensor SID1 is activated. The minimum activation duration is given by the time delay (DELAY). After this minimum activation duration, the sensor is deactivated if referenced sensor SID2 is activated. If there is no SID2 referenced, then the sensor is deactivated after the time delay.
  5. For STYPE=AND, the sensor is activated once both the referenced sensors (SID1 and SID2) are activated.
  6. For STYPE=OR, the sensor is activated once either of the referenced sensors (SID1 or SID2) are activated.
    Figure 3.
  7. For STYPE=NOT, the sensor is active whenever the referenced sensor SID1 is not active.
    Figure 4.
  8. For STYPE=INTER, the sensor is activated once the referenced contact (CID) is impacted. The sensor is deactivated if there is no impact during a time equal to the time delay (DELAY).
    Figure 5.
  9. For STYPE=RWAL, the sensor is activated once the referenced rigid wall (RWID) is impacted. The sensor is deactivated if there is no impact during a time equal to the time delay (DELAY).
    Figure 6.
