STRESS / ELSTRESS
I/O Options and Subcase Information Entry Used to request stress output for all subcases or individual subcases, respectively.
STRESS (sorting,format_list,form,type,location,random,peakoutput,modal, fourier,surf,Neuber, RTHRESH=rthresh, THRESH=thresh, TOP=topn, RTOP=rtop, kpi, psdm, nlout=nloutid,statistics) = option
Argument Options Description
sorting <SORT1, SORT2> This argument only applies to the PUNCH format (.pch file) or the OUTPUT2 format (.op2 file) output for normal modes, frequency response, and transient subcases. It will be ignored without warning if used elsewhere.
SORT1
Results for each frequency/ timestep are grouped together.
SORT2
Results for each grid/element are grouped together. 12
blank (Default)
For Normal Modes Analysis, SORT1 is used; for Frequency Response Analysis, if element SET is not specified, SORT1 is used, otherwise, SORT2 is used; for Transient Analysis, SORT2 is used.
format <HM, H3D, OPTI, PUNCH, OP2, PATRAN, APATRAN, PLOT, HDF5, blank>
HM
Results are output in HyperMesh results format (.res file).
H3D
Results are output in Hyper3D format (.h3d file).
OPTI
Results are output in OptiStruct results format (multiple files).
PUNCH
Results are output in Nastran punch results format (.pch file).
OP2
Results are output in Nastran output2 format (.op2 file). 15
PATRAN
Results are output in Patran format (multiple files).
APATRAN
PLOT
Results are output in Nastran output2 format (.op2 file) when PARAM,POST is defined in the Bulk Data section.
If PARAM, POST is not defined in the Bulk Data section, this format allows the form for complex results to be defined for XYPUNCH output, without having other output.
HDF5
Results are output in the Hierarchical Data format, Version 5 (.h5 file). 20
blank (Default)
Results are output in all active formats for which the result is available.
form <COMPLEX, REAL, IMAG, PHASE, BOTH>
Default (HM only) = COMPLEX
Default (all other formats) = REAL
COMPLEX (HM only), blank
Provides a combined magnitude/phase form of complex output to the .res file for the HM output format.
REAL or IMAG
Provides rectangular format (real and imaginary) of complex output.
PHASE
Provides polar format (phase and magnitude) of complex output.
BOTH (HM only)
Provides both rectangular and polar formats of complex output.
type <VON, PRINC, MAXS, SHEAR, ALL, TENSOR, DIRECT>
Default = ALL, TENSOR
VON
Only von Mises stress results are output (HM, OPTI, and H3D only).
PRINC, MAXS, SHEAR
von Mises and maximum principal stress results are output (HM and H3D only).
ALL
All stress results are output.
TENSOR
All stress results are output. Tensor format is used for H3D output.
DIRECT
All stress results are output. Direct format is used for H3D output.
location <CENTER, CUBIC, SGAGE, CORNER, BILIN, GAUSS>
CENTER (Default)
Element stresses for shell and solid elements are output at the element center only.
CUBIC
Element stresses for shell elements are output at the element center and grid points using the strain gage approach with cubic bending correction.
SGAGE
Element stresses for shell elements are output at the element center and grid points using the strain gage approach.
CORNER or BILIN
Element stresses for shell and solid elements are output at the element center and grid points using bilinear extrapolation. 18
GAUSS
Element stresses for shell and solid elements are output at the element center and the Gauss integration points. 18
random <PSDF, RMS, PSDFC>
No default
PSDF
Requests PSD and RMS results from Random Response Analysis to be output for solid and shell elements only. 13 21
Only valid for OUTPUT2 and H3D formats. The "RMS over Frequencies" output is at the end of the Random results in the .h3d file and labeled "Simulation 1" in the .op2 file.
RMS
Requests only the "RMS over Frequencies" result from Random Response Analysis to be output for solid and shell elements only. 13 21
Only valid for OUTPUT2 and H3D formats. It is labeled "Simulation 1" in the .op2 file.
PSDFC
Requests PSD, RMS and RMS (cumulative) results from random response analysis to be output.
Only valid for H3D format. The "RMS over Frequencies" output is at the end of the random results.
PSDM <PSDM>
Default = blank
If PSDM is present, PSD Moments, Number of Peaks and Irregularity Factors for Segalman von Mises stress will be output. For BAR/BEAM elements, axial stress will be adopted instead. Only punch file is supported. 23
peakoutput <PEAKOUT>
Default = blank
If PEAKOUT is present, only the filtered frequencies from the PEAKOUT card will be considered for this output.
modal <MODAL>
Default = blank
If MODAL is present, stresses of the structural modes and residual vectors are output to the H3D, PUNCH and OUTPUT2 files for Modal Frequency Response and Transient Analysis.
fourier <FOURIER>
Default = blank
Stresses output for Modal/Direct Transient Response Analysis with Fourier Transformation.
FREQ
Frequency domain 24
TIME
Time domain 24
surf <SURF>
Default = blank
If SURF is present, OptiStruct automatically creates a 2D skin on the outer surfaces of solid elements in the model. The stresses of the skin elements are output based on the selected option.
Neuber <NEUBER>
Default = blank
If NEUBER is present, the von Mises stresses, corrected with Neuber rule are output to the H3D file. 19
mnf <MNF, NOMNF>
MNF (Default)
Stresses are output to the .mnf file.
NOMNF
Stresses are excluded from the .mnf file.
THRESH <thresh>
Real
Default = blank
Specifies an absolute threshold under which stress results should not be output. 17
RTHRESH <rthresh>
0.0 < Real < 1.0
Default = blank
Specifies a relative threshold as a fraction of the maximum von Mises stress under which results should not be output. For example, if VMS is the maximum von Mises stress in the model, then stress results below VMS*rthresh are excluded from the output.
TOP <topn>
Integer > 0
Default = blank
Only the top topn stress values should be output.
RTOP <rtop>
0.0 < Real < 1.0
Default = blank
Only the top fraction ("rtop") of the total number of stress values should be output. For example, if STOT is the total number of stress values in the model, then only the top STOT*rtop values are output.
kpi <KPI>
Default = blank
Key Performance Indicators for Strain results are output in the *.kpi ASCII file. 22
nlout <nloutid>
No default
ID of an NLOUT Bulk Data Entry.
If present, the incremental output control parameters are taken from the referenced NLOUT Bulk Data Entry, instead of the one selected by Subcase Entry NLOUT, when results are written into the *_impl.h3d file. 25
statistics <STATIS, OSTATIS, or blank> Stress Statistics over time in Linear Transient Analysis are controlled by this option. 26
STATIS
Stress statistics are output in addition to regular stress output at each timestep for Linear Transient Analysis.
OSTATIS
Only stress statistics are output for Linear Transient Analysis.
blank (Default)
option <YES, ALL, NO, NONE, SID, PSID>
Default = ALL
YES, ALL, blank
Stress results are output for all elements.
NO, NONE
Stress results are not output.
SID
If a set ID is given, stress results are output only for elements listed in that set.
PSID
If a property set ID is given, stress results for the elements referencing properties listed in the property set are output.
  1. When a STRESS command is not present, stress results are output for all elements for all Linear Static Analysis, Nonlinear Quasi-static Gap Analysis, and Inertia Relief Analysis subcases.
  2. HyperView can internally derive STRESS results from the stress tensor when the options TENSOR or ALL are used. If the option DIRECT is used, it will display the stress result that were directly computed.
  3. For elements that reference PCOMP or PCOMPG properties, the STRESS I/O Option controls only stress results for the homogenized composite. The CSTRESS I/O Option must be used to obtain ply stress and failure index results.
  4. Only VON, TENSOR and ALL options are accepted for type in Frequency Response Analysis. HyperView can internally derive other STRESS results from the stress tensor for Frequency Response Analysis.
  5. The form argument is only applicable for Frequency Response Analysis. It is ignored in other instances.
  6. The forms BOTH and COMPLEX do not apply to the .frf output files.
  7. Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
  8. Multiple instances of this card are allowed; if instances are conflicting, the last instance dominates.
  9. For optimization, the frequency of output to a given format is controlled by the I/O option OUTPUT.
  10. For Normal Modes Analysis output, if there is USET U6 data, the stresses for each residual displacement vector associated with the USET U6 DOF are also output to the H3D, PUNCH, and OUTPUT2 files.
  11. For Modal Frequency Response and Transient Analysis, the stress vectors associated with the residual vectors are written to the .op2 and .pch files after the modal stress vectors if the keyword MODAL is used.
  12. In general, HyperView does not recognize the SORT2 format for results from the .op2 file. When results are output only in SORT2 format (<Result Keyword> (SORT2, OUTPUT2, ...)), the results are written by OptiStruct into the .op2 file in SORT2 format, but when the .op2 file is imported into HyperView, the results in SORT2 format are not recognized. Therefore, the SORT1 option is recommended for results output in OUTPUT2 format and SORT2 option is recommended for results output in PUNCH format.
  13. PSDF and RMS von Mises stress results based on the Segalman Method are also written to the .h3d file for Random Response Analysis (only available in the H3D format).
  14. The four-letter abbreviation STRE is interchangeable with STRESS.
  15. format=OUTPUT2 can also be used to request results to be output in the Nastran output2 format (.op2 file).
  16. STRESS(SURF) is not available for EXPDYN solution sequences. OptiStruct will error out, if EXPDYN is the only subcase in the model, and will display a warning message, if there are other subcases in the model, for which STRESS(SURF) can be output. STRESS(SURF) is not available, if neither MAT nor MAT2 are not assigned to the solid materials in the model. Additionally, STRESS(SURF) output is also not available, if MAT1 (with MATS1) is assigned to the elements in the model. Surface shell is not generated if there are only nonlinear materials in the model.
  17. The threshold options (THRESH, RTHRESH, TOP, and RTOP) are available in H3D, OP2, and PUNCH format for Static, Normal Mode, Frequency Response, Transient, and Random Response Analyses only. For H3D, the filter is applied to each dimension of elements (shells, solids, beams, welds, etc.), while for OP2 and PUNCH, it is applied to each element type (quad4, tria3, quad8, etc.).
  18. The GAUSS results are currently only supported for H3D and OP2 files. CORNER results are not supported in OPTI format. To display CORNER/GAUSS stress results in HyperView, activate the Use Corner Results check box in the Contour panel.
    CORNER and GAUSS results (Stress, Total Strain, and Plastic Strain) are supported for both Shell (including composite shells) and Solid elements.
    Static Eigenvalue Direct Frequency Response Modal Transient/ Frequency Response Direct Transient Nonlinear Static Nonlinear Transient Response Spectrum Random
    Corner Stress H3D, OP2, PCH H3D, OP2, PCH H3D, OP2, PCH H3D, OP2, PCH H3D, OP2, PCH H3D, OP2, 2 PCH 2 H3D, OP2, 2 PCH 2 H3D, OP2 1, PCH 1 H3D, OP2, PCH
    Corner Strain H3D, OP2, PCH H3D, OP2, PCH H3D H3D, OP2, 2 PCH 2 H3D, OP2, 2 PCH 2 OP2 1
    Gauss Stress H3D, OP2 H3D, OP2 2 H3D, OP2 2
    Gauss Strain H3D, OP2 H3D, OP2 2 H3D, OP2 2
  19. Neuber corrected stresses are calculated based on the von Mises stresses from elastic analysis, the Young's modulus, and the nonlinear material properties defined on MATS1 Bulk Data Entry. Neuber Stress results are available as elemental results, Gauss point stresses, and Corner Neuber stresses. Neuber Strain results are available as elemental results, Gauss point strains, and Corner Neuber strains. Neuber Stress/Strain is supported for Static, Frequency Response, and Transient Analysis for H3D output.
  20. The HDF5 output is printed to a .h5 binary results file. The current support of HDF5 output format is:
    1. In case of Linear Static and Normal Modes analysis,
      • The supported element types for element-based results (in .h5 format) are:
        Result Elements Supported
        FORCE/ELFORCE CBAR, CBEAM, CONROD, CTRIA3, CTRIA6, CQUAD4, CQUAD8
        STRESS CROD, CBAR, CBEAM, CONROD, CELAS1, CELAS2, CBUSH, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CTETRA, CHEXA, CPENTA
        STRAIN
      • Corner results are also available for the above results with CQUAD4 and CQUAD8 elements.
    2. In case of Nonlinear Static analysis,
      • The supported element types for STRESS and STRAIN results (in .h5 format) are:
        STRESS,
        STRAIN
        CROD, CELAS1, CBAR, CBEAM, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CHEXA, CPENTA, CTETRA
      • Corner results are also available for CQUAD4 and CQUAD8.
      • DISPLACEMENT, STRESS and STRAIN results are also available on-the-fly during the analysis, if the NLOUT entry is defined in the subcase.
    3. In case of Linear Buckling analysis, only DISPLACEMENT result is available in .h5 format.
  21. PSDF and RMS stress results are output in the element coordinate system in H3D and OP2 files.
  22. KPI output includes maximum value for Stress with respect to the corresponding property. It is supported for linear and nonlinear static analysis only. Stresses and Strains are supported only for shells and solids. KPI output can also be output for a particular SET using the SID option.
  23. PSDM results are based on Segalman von Mises stress and are output in the Punch file using the following format:
    1D/3D Elements
    M0, M1, M2, M4, Number of Peaks, Irregularity Factor
    2D Elements
    Z1, M0, M1, M2, M4, Number of Peaks, Irregularity Factor, Z2, M0, M1, M2, M4, Number of Peaks, Irregularity Factor
    For more information on the PSDM output data, refer to Random Response Fatigue Analysis in the User Guide.
  24. The FREQ and TIME options are only valid for Modal/Direct Transient Analysis with Fourier Transformation. When FREQ is present, the displacements in frequency domain would be output in a dummy frequency subcase, which shares the same ID with the transient subcase.
  25. nlout= <nloutid> applies only to implicit nonlinear subcases.
  26. Stress Statistics are only supported for Direct and Modal Linear Transient Analysis. Only Centroid stress is supported and only 2D and 3D elements are currently supported.
    Only H3D output is supported for Stress Statistics.
    The following statistics over time are output for Linear Transient Analysis when STATIS or OSTATIS is specified:
    Statistics
    Supported Stress Result Types
    Minimum
    von Mises, P1 (Major), P2 (Mid), P3 (Minor)
    Time of Minimum
    Maximum
    Time of Maximum
    Abs-Max
    Time of Abs-Max
    Arithmetic Mean
    Root Mean Square (RMS)
    Variance
    Standard Deviation
    After loading the H3D file, the Stress Statistics in HyperView can be viewed.
    Various statistics can be chosen from the sub-menu under Stress Statistics(s).
1 Only for shell elements.
2 OP2 and PCH files for NLSTAT and NLTRAN analysis only include the results at the final timestep.
