SUBCOM
Subcase Information Entry Delimits and identifies a combination subcase.
SUBCOM = n
SUBCOM = 125
Argument | Description |
n | Subcase identification
number. (Integer > 2) |
- A SUBSEQ command must follow this command.
- SUBCOM may only be used with STATIC subcases.
- Output requests above the subcase level will be used.
- If the referenced subcases contain thermal loads or element deformations, the temperature field in the SUBCOM must be defined with a TEMP(LOAD) command or the element deformations with a DEFORM command.
- If the reference subcases contain STATSUB(PRELOAD), then all of the referenced subcases must contain the same STATSUB(PRELOAD); the same STATSUB(PRELOAD) should also be used in the SUBCOM.
- SUBCOM is not supported for optimization. Use DRESP2/DRESP3 to create synthetic response would be the solution.
