FORCOS
The Forcos function evaluates a Fourier Cosine series at a specific value .
Arguments
- The independent variable. For example, to specify time as the independent variable, specify as TIME.
- The shift in the Fourier Cosine series.
- The fundamental frequency of the Fouries series. It is assumed to be specified in radians per unit of unless a D is used after the value.
- The constant bias term.
- The coefficients for the Fourier Cosine series.
Definition
<Motion_Joint
id = "301001"
label = "Motion_Joint name"
type = "EXPRESSION"
val_type = "D"
expr = "FORCOS(TIME,0.1,6.28,0.1,0.2)"
joint_id = "10003"
joint_type = "R"
