Model ElementMforce defines a distributed force on a flexible body (CMS) in
MotionSolve.
Mforce can be implemented three ways:
- The force shape is scaled by a function expression.
- The force shape is scaled in a compiled user-subroutine.
- The force shape is scaled in an scripted user-subroutine.
Attribute Summary
Name |
Property |
Modifiable by
command? |
Designable? |
id |
Int
NO |
label |
Str
Yes |
case_index |
Int
Yes |
scale |
Function () |
Yes |
flex_body |
Reference (FlexBody) |
Yes |
function |
Function ("MFOSUB") |
Yes |
force |
Function () |
Yes |
routine |
Routine () |
active |
Bool
Yes |
Usage
#1: Scale factor defined in an expression for scaling a modal force shape
Mforce (flex_body=objFlexBody, case_index=int, scale=double, optional_attributes)
#2: Scale factor or modal force defined in an compiled user-written subroutine
Mforce (flex_body=objFlexBody, function=userString, routine=string optional_attributes)
#3: Scale factor defined in a Python functionMforce (flex_body=objFlexBody, function=userString, routine=functionPointer, optional_attributes)
Attributes
- flex_body
- Reference to a Flex_Body.
- Defines the ID of a flex body on which the modal load is applied.
- The flex_body attribute is mandatory.
- case_index
- Integer
- Specifies the modal load case number that is used to define the shape of the
distributed load.
- The case_index attribute is mandatory.
- scale
- Double
- Specifies an expression for the scale factor to be applied to the load case
referenced by case_index.
- The scale attribute is mandatory.
- flex_body
- function
- String
- The list of parameters that are passed from the data file to the
user-defined subroutine.
- The function attribute is mandatory.
- routine
- String
- Specifies an alternative name for the user subroutine. The name consists
of two pieces of information, separated by "::". The first is the
pathname to the shared library containing the function that computes the
response of the user-defined Field. The second is the name of the
function in the shared library that does the computation.
- An example is: routine="/staff/altair/myfield.dll::mymfosub".
- "/staff/altair/mymfosub.dll is the DLL
- "mymfosub" is
the function within this DLL that performs the
calculations
- The routine attribute is optional. When not
specified, it defaults to MFOSUB.
- force
- String
- Specifies whether the user subroutine returns a shape that is to be
scaled or the actual modal force itself. Set this to
"USER" to specify that the
MFOSUB returns the actual force.
- The force attribute is optional. When it is not
specified, MotionSolve will assume that the
user-subroutine computes a scale factor, not a modal force.
The force shape is scaled in a scripted user-subroutine
- flex_body
- function
- String defining a valid user function MotionSolve
expression.
- The list of parameters that are passed from the data file to the user
defined subroutine where the Variable is defined.
- routine
- Pointer to a callable function in Python.
- An example is: routine=myModalLoad.
- myModalLoad is a Python
function or method that can be called from wherever the model
resides.
- The attribute routine is optional.
- When not specified, routine defaults to
MFOSUB.
- force
- String
scaled or the actual force itself. Set this to "USER"
to specify that the MFOSUB returns the actual
force.
Optional attributes - Available to all variants
- id
- Integer
- Specifies the element identification number. This number must be unique
among all the Mforce objects in the model.
- This attribute is optional. MotionSolve will
automatically create an ID when one is not specified.
- Range of values: id > 0
- label
- String
- Specifies the name of the Mforce object.
- This attribute is optional. When not specified, MotionSolve will create a label for you.
- active
- Bool
- Select one from True or False.
- True indicates that the element is active in
the model and it affects the behavior of the system
- False indicates that the element is inactive in
the model and it does not affect the behavior of the system. It
is almost as if the entity was removed from the model, of course
with the exception that can be turned "ON" when
desirable.
- The attribute active is optional. When not specified,
active defaults to True.
The example below shows a definition of a
Mforce.
disturbanceLoad = Mforce (label="Disturbance", flex_body=wing, case_index=1, scale="1.0 + 0.2*sin(360d*time) + 0.1*sin(360d*time*3)")
- See Properties for an
explanation about what properties are, why they are used, and how you can extend
these.
- For a more detailed explanation about Mforce,
see the Force: FlexModal.
