SENSUB/SEVSUB
ModelingUsed to compute/evaluate the value for a sensor element. SENSUB can detect an event, while SEVSUB is used to return the scalar value computed when the event defined by the sensor occurs.
Use
User-defined request calling a SENSUB/SEVSUB for the calculation of output quantities:
<Sensor_Evaluate
     id                  = "100"
     type                = "USERSUB"
     usrsub_param_string = "USER(2,22,11)"
     usrsub_dll_name     = "NULL"
  <Sensor_Event
     label               = "Sensor/100"
     id                  = "100"
     type                = "USERSUB"
     usrsub_param_string = "USER(22,11)"
     compare             = "GE"
     value               = "0."
     evaluate_id         = "100"
     error_tol           = "0.0001"
The sensor event element calls a SENSUB subroutine, while the sensor evaluate element returns the value computed in the SEVSUB when the event detected by the sensor occurs.
Fortran Calling Syntax
SUBROUTINE SENSUB (ID, TIME, PAR, NPAR, IFLAG, VALUE)
SUBROUTINE SEVSUB (ID, TIME, PAR, NPAR, IFLAG, VALUE)
C/C++ Calling Syntax
void STDCALL SENSUB (int *id, double *time, double *par, int *npar, int *iflag, double *value)
void STDCALL SEVSUB (int *id, double *time, double *par, int *npar, int *iflag, double *value)
Python Calling Syntax
def SENSUB(id, time, par, npar, iflag):
    return value
def SEVSUB(id, time, par, npar, iflag)
    return value
MATLAB Calling Syntax
function value = SENSUB(id, time, par, npar, iflag)
function value = SEVSUB(id, time, par, npar, iflag)
Attributes
ID
[integer]
The user-defined sensor element identifier.
TIME
[double precision]
The current simulation time.
PAR
[double precision]
An array that contains the constant arguments from the list provided in the user-defined statement.
NPAR
[integer]
The number of entries in the PAR array.
IFLAG
[logical]
Initialization flag.
Output
VALUE
[double precision]
The output value that contains the value of the function that the sensor event returns (for SENSUB).
VALUE
[double precision]
The output value that contains the value of the function that the sensor evaluate entity computes (for SEVSUB).
    ipar =2*[0]
    twopi =2.0*pi
    ipar[0] = int(par[0])
    ipar[1] = int(par[1])
    [AZ, errflg] = py_sysfnc("AZ", ipar)
    value = fmod(AZ,twopi) - (pi/2.0)
    return value
def SEVSUB(id, time, par, npar, iflag):
    itype =int(par[0])
        ipar =1*[0]
        ipar[0] =int(par[1])
        [senval, errflg] = py_sysfnc("SENVAL", ipar)
        value = senval+1.0
    return value
