Save
Command ElementThe Save command causes MotionSolve to write out the model data to a MotionSolve XML file.
<Save
model_file = "valid_file_name.xml"
Attributes
- model_file
- The name of the MotionSolve XML file to be created.
The following example demonstrates the use of the Save command to save the model as a MotionSolve XML file after a transient simulation.
<Command
<Simulate
analysis_type = "Transient"
end_time = "3."
print_interval = "0.01"
<Save
model_file = "save1.xml"
<Simulate
end_time = "5."
<Save
model_file = "save2.xml"
</Command>
- The resulting MotionSolve XML file only contains the model block. It does not contain the command block.
- The MotionSolve XML created by the Save command may be loaded using Load_Model command for additional simulations.
