MV-3021: Optimize an Impact Absorber
In this tutorial you will learn how to setup an optimization problem using MotionSolve's Optimization Wizard for an impact absorber.
- Defining stiffness and damping of SpringDamper element as design variables
- Defining responses of type MaxVal
- Using the responses as objectives
- Running the optimization and post-processing the results
- Introduction
- An impact absorber is modeled as a single degree of freedom system with a
mass m, a linear stiffness k and a linear damping coefficient c. The
velocity of the mass is 1 m/s; Mass m = 1 kg and a transient analysis end
time of 12 seconds is used.Figure 1.
Add Design Variables
In this step, you will add design variables for the optimization.
Add Response Variables
In this step you will add response variables for the optimization.
- Maximum z direction acceleration of mass
- Maximum z direction displacement of mass
Add Objectives and Constraints
Now you will add objectives and constraints to the problem.
Run the Optimization
In this step you will run the optimization.
Post-Process
In this step, you will post-process the optimization results of the impact absorber.
