MV-3040: Durability and Fatigue Tools
In this tutorial, you will learn how to convert results simulation run into file formats that can be used for fatigue analysis (using a tool like NCode) and how to write a fatigue analysis file from the MotionView animation window.
- Fatigue Prep
- Access this feature from the menu bar by clicking .
Table 1. Original Format Translated Format Altair .H3D flexbody (modal content) Ncode .FES/.ASC Ncode .DAC Altair .ABF ADAMS .RES (modal participation factors) Ncode .DAC ADAMS .REQ files (loads information) Ncode .DAC Altair .PLT Ncode .DAC ADAMS .REQ files (loads information) MTS .RPC - Flex File Gen
- build plots
- From the HyperGraph client, access this feature by clicking the (build plot) icon.
Use the Fatigue Prep Wizard
In this step, you will use the Fatigue Prep Wizard to convert an H3D file into an FES file.
Convert ADAMS results from REQ to DAC
In this step, you will convert the results of an ADAMS run to DAC files using the Fatigue Prep translator.
Use the Flex File Tool
Now you will learn to use the Flex File tool.
View the Fatigue Results
In this step you will view the Fatigue results in the animation window.
