_frames.html file
The _frames.html file is a HyperText Markup Language file.
File Creation
This file is output when the H3D OUTPUT is chosen.
File Contents
The file contains two frames. The top frame opens one of the .h3d files using the HyperView Player browser plug-in. The .h3d file opened depends on the results selected for display in the bottom frame. The bottom frame opens the _menu.html file file, which facilitates the selection of results to be displayed.
  1. Requires HyperView Player plug-in to be installed.
  2. This file is linked to from the "Results Summary" section of the .html file file and is created primarily for this purpose.
