RD-E: 4900 Bird Strike on Windshield
Using SPHCEL to simulate a bird hitting a windshield.
Options and Keywords Used
- /SPHGLO
- /SPHCEL
- /MAT/LAW6 (HYDRO or HYD_VISC)
- /MAT/LAW36 (PLAS_TAB)
- /MAT/LAW27 (PLAS_BRIT)
- /PROP/TYPE34 (SPH)
- /PROP/TYPE11 (SH_SANDW)
- /INIVEL/TRA
- Boundary condition (/BCS)
- Rigid body (/RBODY)
- Interface (/INTER/TYPE7 and /INTER/TYPE12)
Input Files
- Bird Strike on Windshield
- <install_directory>/hwsolvers/demos/radioss/example/49_bird_strike_on_windshield/*
Model Description
Units: mm, ms, kg, KN, GPa
- Material Properties
- Initial density
- 9.82242e-7
- C1
- 2.24, with SPH cells property /PROP/SPH
- mp
- 1.725149e-4
- qa
- 2e-30
- qb
- 1e-30
- order
- 0
- h
- 6.286
- In property, mp is the mass of each particle. There are 11190 particles in the bird model, so the bird weighs 11190*1.725149e-4 = 1.93kg (4 pounds).
- Set qa to 2e-30 and qb to 1e-30
for no damping.
To properly simulate a bird strike, the compression phase of the bird is the most important; therefore, the initial compression wave should properly propagate through the bird. Energy conservation is also important, so that the bird communicates the most realistic amount of energy to the target, thus ensuring that the impact is reasonably conservative.
A low value of qa and qb should be chosen. The behavior of the bird for very low values of the damping is very similar, and there is no evidence of instability; therefore, negligible values of qa and qb (that is 1-30 and 2-30) are considered.
- In property, h is smoothing length:
(1) The smoothing length, h is highly recommended to use the minimal distance between any particle and its closest neighbor.
- SPH correction order is used to satisfy the consistency conditions. It is generally to insure a better representation when the particles are not so well organized than into a hexagonal compact net. High order value is very expensive. In this example, set order to 0.
For the windshield in this example, use composite material with matrix glass and plastic fabric. Both use /MAT/PLAS_BRIT (composite with isotropic layers).
Glass Matrix
- Initial density
- 1.74e-6
- E-Modules
- 61 [GPa]
- Poisson ratio
- 0.3
- Yield stress, a
- 0.045 [GPa]
- Plasticity hardening, b
- 0.05
- 0.01
- 0.03
- element deleted at
- 0.06
Fabric Plastic
- Initial density
- 8e-7
- E-Modules
- 3 [GPa]
- Poisson ratio
- 0.3
- Yield stress, a
- 1e30 [GPa], with /PROP/SH_SANDW
- Thickness of windshield
- 9 [mm]
- Number of layers, N
- 9
- Ithick
- 1
- Initial density
- 2.7E-6
- E-Modules
- 73.1 [GPa]
- Poisson ratio
- 0.33
- /MAT/PLAS_JOHNS
- Initial density
- 7.8E-6 [
- E-Modules
- 210 [GPa]
- Poisson ratio
- 0.28
- Yield stress, a
- 0.58 [GPa]
- Hardening parameter, b
- 0.6
- Hardening exponent, n
- 1
- Strain rate coefficient
- 0.017
- /PROP/BEAM
- Area
- 50.265 [mm2]
- Iyy = Izz
- 201.061 [mm4]
- Ixx
- 403.12 [mm4]
Model Method
- Bird modelingA 4 pound bird model with 11190 particles, the distributions follow a hexagonal compact net. The cell distribution must be cubic centered. The diameter for each particle is about 5.0 mm.
- SPH simulation setupIn order to define the SPH bird, the following keywords are needed:
- Use /PROP/SPH to define the bird SPH cells property.
- Use /SPHCEL to define SPH cells for bird. Use bird part ID in this keyword.
- Use /SPHGLO to defined global parameter for this simulation.
- Set = 0.25 (default value). is a security coefficient which is used when searching for neighbors, so that for each particle more than the actual neighbors are found. The computational time can be reduced.
- Contact between SPH bird and structure and impact setup
- Use interface TYPE7 to simulate the Contact between SPH bird and structure. Set the structure as master and the bird as slave.
- Set Igap=1 (use variable gap). The gap is 1/2(particle diameter)+1/2(thickness of the target). This is the physical value for contact.
- The stiffness between bird and structure are quite different. In order to get results more close to reality. Normally set Istf=0 and Stfac=0.1. This means interface stiffness equals to 0.1 times stiffness of master side (structure).
- Use /INIVEL/TRA to set bird part with initial velocity 80m/s strike on the structure.
- Connection between the windshield and fuselage
- Use spring beam to simulate the weld connection between windshield and fuselage, and use tied contact to connect them.
- Other remarks
In order to decrease the size of animation files and get the best display of SPH particles, use /ANIM/VERS/44 in Engine file.
Results
Conclusion
- The size of the mesh and the number of particle seems to be a good compromise between the accuracy of the problem and the CPU considerations (especially for larger models such as 4 and 8 pound birds).
- For interface parameters default values could be used.
- The simplified viscous law is good.
- Impact velocity remains small compared to the sound speed in the material (that is less than 300 m/s).
- The h value should be set to a value larger than the inter-cell distance (to avoid excessive de-cohesion), but not too large to avoid excessive energy absorption by the bird.
- Using this model, the discrepancies between the real tests and the simulations are usually due to parameters independent from bird modeling: boundary conditions, target material laws and test sensitivity and so on.
- The final shape of the bird is more "physical", so more experimental data would be required, for instance multiple penetration cases.
