/EOS/MURNAGHAN
Block Format Keyword Describes the Murnaghan equation of state.
/EOS/MURNAGHAN/mat_ID/unit_ID
eos_title
K0 K1 P0 Psh ρ 0
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
eos_title EOS title.
K0 Material parameter.
(Real)
[ Pa ]
K1 Material parameter.
(Real)
P0 Initial pressure.
(Real)
[ Pa ]
Psh Pressure shift.
(Real)
[ Pa ]
ρ 0 Reference density.
Default = material density (Real)
[ kg m 3 ]
/UNIT/1
unit for mat
                   g                  mm                  ms
/MAT/HYDPLA/7
IDEAL-GAS
#              RHO_I               RHO_0
             1.22e-3             1.22e-3
#                  E                  nu
                   0                   0
#                  a                   b                   n             eps_max           sigma_max
                1E30                   0                   0                   0                   0
#               Pmin
                   0
/EOS/MURNAGHAN/7
NaCl
#                 K0                  K1                  P0                 PSH                RHO0
                24.0               5.390                 1.0                   0            2.165e-3
/ALE/MAT/7
#enddata
  1. This equation of state is also known as Tait Equation of State.(1)
    P ( V ) = K 0 K 1 [ ( V V 0 ) K 1 1 ]
    Where K0 and K1 are material parameters.
  2. Equations of state are used by Radioss to compute the hydrodynamic pressure and are compatible with the material laws:
    • /MAT/LAW3 (HYDPLA)
    • /MAT/LAW4 (HYD_JCOOK)
    • /MAT/LAW6 (HYDRO or HYD_VISC)
    • /MAT/LAW10 (DPRAG1)
    • /MAT/LAW12 (3D_COMP)
    • /MAT/LAW49 (STEINB)
    • /MAT/LAW102 (DPRAG2)
    • /MAT/LAW103 (HENSEL-SPITTEL)
1 Murnaghan, F. D. "The compressibility of media under extreme pressures." Proceedings of the National Academy of Sciences 30, no. 9 (1944): 244-247
