/FAIL/EMC
Block Format Keyword Describes failure dependent on effective plastic strain.
/FAIL/EMC/mat_ID/unit_ID
a n b0 c
Card 2
γ ˙ε0
Optional Line
fail_ID
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
a Hosford exponent.
Default = 1.0 (Real)
n Stress state sensitivity exponent.
(Real)
b0 Strain to fracture for uni-axial tension. 2
c Friction parameter for triaxiality.
Default = 0.0 (Real)
γ Strain rate sensitivity parameter.
(Real)
˙ε0 Reference strain rate.
Default = 1030 (Real)
[1s]
fail_ID (Optional) Failure criteria identifier. 3
Example (Metal)
Fracture parameters could be identified with tests like uniaxial tension ( η=1/3,θ=1), pure shear ( η=0,θ=0), and axisymmetric compression ( η=2/3,θ=1).
#RADIOSS STARTER
/UNIT/1
unit for mat
                 Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW84/1/1
Swift-voce (metal)
#              RHO_I
                8E-9
#                  E                  NU
             206000.                0.30
#                P12                 P22                 P33               QVOCE               BVOCE
                -0.5                  1.                  3.            524.0000                 25.
#                G11                 G22                 G33                  K0               ALPHA
                -0.5                  1.                  3.                100.                 0.5
#                 AN                EPS0                  NN               CEPSP               DEPS0
               1000.             0.00128               0.200               0.014              0.0011
#                ETA                  CP                TINI                TREF               TMELT
                 0.9              420e+8                 293                293.               1700.
#              MTEMP              DEPSAD
               0.921               1.379
/FAIL/EMC/1/1
#         exponent_a          exponent_n              coef_b              coef_c
                 1.9                 0.2                0.20                 0.0
#               GAMA               DEPS0
                 0.0                 1.0
#ENDDATA
  1. The failure criteria is calculated as:(1)
    Dfail=ΔD>1
    Where,(2)
    ΔD=Δ¯εp¯εp,fail
    Where,(3)
    ¯εp,fail=b(1+c)1n{[12((f1f2)a+(f2f3)a+(f1f3)a)]1a+c(2η+f1+f3)}1n
    Where, f1 , f2 and f3 are functions of the Lode angle θ :(4)
    f1=23cos[π6(1θ)]
    (5)
    f2=23cos[π6(3+θ)]
    (6)
    f3=23cos[π6(1+θ)]
    With(7)
    θ=12πarccos[332J3(J2)3/2]
    Where, η is the traixiality η=σmσVM=I133J2 .
  2. The coefficient, b is computed as:
    b=b0[1+γln(˙¯εp˙¯ε0)] if ˙¯εp>˙¯ε0 else b=b0
  3. The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL for brick. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL for brick).
