Radioss Files
Table of Radioss files, up to Radioss version 4
4x extension | Type | Format | Remark | Read by | Written by |
RunnameD00 | Starter input | ASCII | Starter | HyperCrash
HyperMesh |
RunnameD0A | Starter input | ASCII | Starter | HyperCrash
HyperMesh |
RunnameDnn | Engine input | ASCII | Default binary | Engine | User |
RunnameRnn | Restart file | Any | Engine | Starter Engine |
RunnameAnnn | Animation | IEEE binary | HyperView | Engine | |
Animation | H3D | HyperView | HvTrans thru run script | ||
RunnameTnn | Time history | Any | Default IEEE binary | HyperGraph | Engine |
RunnameTnnx | Time history | Any | Default IEEE binary | HyperGraph | Engine |
Runname@Tnn | MNOISE file | Any | HyperGraph | Engine | |
RunnameLnn | Listing | ASCII | Engine | ||
RunnameYnnn |
Output | ASCII | Starter | Engine | |
RunnameCnn | Control file | ASCII | Engine | User |
Version 5.1: Radioss file extensions
5x extension | Type | Format | Remark | Read by | Written by |
Runname_0000.rad | Starter input | ASCII | Starter | HyperCrash
HyperMesh |
Runname_0000_a.rad | Starter input | ASCII | Starter | HyperCrash
HyperMesh |
Runname_run#.rad | Engine input | ASCII | Engine | User | |
Runname_run#_cpu#[_C].rst | Restart file | Any | Default binary | Engine | Starter Engine |
if Radioss Engine option
/TH/VERS/41 is used
(default): RunnameTnn if Radioss Engine option /TH/VERS/51 is used: Runname_run#.thy |
/TH/VERS/41 is used (default):
if Radioss Engine option /TH/VERS/51 is used: Runname_run#_x.thy “x”: letter (a to i) |
Runname_run#_@.thy | MNOISE file | Any | HyperGraph | Engine | |
Runname_run#.lis | Listing | ASCII | Engine | ||
Runname_nnnn.out or
RunnameYnnn according to the /IOFLAG keyword: if if |
Runname_run#.ctl | Control file | ASCII | Engine | User |
Version 9.0: Radioss file extensions
Runname_run#.lis becomes Runname_run#.out
Runname_nnnn.out becomes Runname_nnnn.sty
9x extension | Type | Format | Remark | Read by | Written by |
HyperMesh |
HyperMesh |
Runname_run#.rad | Engine input | ASCII | Engine | Engine | |
Runname.h3d | Animation | H3D | HyperView | HvTrans thru run script | |
/TH/VERS/41 is used
/TH/VERS/41 is used
(default): RunnameTnnx if Radioss Engine option /TH/VERS/51 is used: Runname_run#_x.thy “x”: letter (a to i) |
Runname_run#.out | Output | ASCII | Engine | ||
Runname_nnnn.sty or
RunnameYnnn according to the /IOFLAG keyword: if Irootyy = 2: RunnameYnnn if Irootyy ≠ 2: Runname_#run.sty |
Runname_nnnn.sta | State file | ASCII | Starter | Engine | |
run#: RADIOSS run number (four digits) from 0000 to 9999
cpu #: number of processors (four digits)
cpu # = 0000 = SMP RADIOSS Version
cpu # = 0001 to 9999 = SPMD RADIOSS Version
C: restart letter (see /RFILE option in the RADIOSS Engine manual)
Version 12.0: Radioss file extensions
4x Extension Format | 12x Extension Format | Type | Format | Remark | Read by | Written by |
RunnameD00 | Runname_0000.rad | Starter input | ASCII | Starter | HyperCrash
HyperMesh |
RunnameDnn | Runname_run#.rad | Engine input | ASCII | Engine | User | |
RunnameRnn | Runname_run#_cpu # [_C].rst | Restart file | Any | Default binary | Engine | Starter Engine |
RunnameRnn | RunnameAnnn | Animation | IEEE binary | HyperView | Engine | |
N/A | Runname.h3d | Animation | H3D | HyperView | Engine (starting in 2018) or HvTrans thru run script | |
RunnameTnn | if Radioss Engine option
/TH/VERS/41 is used
(default): RunnameTnn |
RunnameTnnx | if Radioss Engine option
/TH/VERS/41 is used
Runname@Tnn | Runname_run#_@.thy | MNOISE file | Any | HyperGraph | Engine | |
RunnameLnn | Runname_run#.out | Listing | ASCII | Engine | ||
RunnameLnn | Runname_nnnn.sty or
RunnameYnnn according to the /IOFLAG keyword if Irootyy = 2: RunnameYnnn if Irootyy ≠ 2: Runname_#run.sty |
Runname_run#.sta | State file | ASCII | Starter | Engine | ||
RunnameCnn | Runname_run#.ctl | Control files | ASCII | Engine | User |
run# : RADIOSS run number (four digits) from 0000 to 9999
cpu # : number of processors (four digits)
cpu # = 0001 to 9999 = MPP (SPMD) RADIOSS Version
In case of Single Input File, Engine options can be added into Starter file. See Single File Input for details.
What is the difference between the "Input format" and the Radioss version which is used?
The input format (V41, V44, V51, V90, and so on) corresponds to the format of the Radioss input data file, whose name is RunnameD00 for input formats up to V44 or Runname_0000.rad for input formats coming from V51 or higher.
For input formats up to V44, the input format is declared at the first line of the Starter input file. This conforms to the version of the input manual.
For input formats from V51 onwards, the input format is declared in the keyword /BEGIN, which must be the first uncommented line after the line: “#RADIOSS Starter”.
For every new Radioss main release (V41, V44, V51, V90, and so on), a new input manual is provided, which presents the characteristics of the new input format, and information on new keywords.
By ascending compatibility, a RunnamD00 or Runname_0000.rad file conforming to a given manual will be read normally by the next Radioss release (but not the opposite).
** ERROR IN INPUT FORMAT INPUT VERSION 42 IS NOT SUPPORTED
