/GRSH3N
Block Format Keyword Describes the 3 node shell groups.
Input Type Keywords: 3 Node Shell Group
- Keyword
- Input Type
- /GRSH3N/GEN_INCR
- Generate list by increment
- /GRSH3N/GENE
- List of 3 node shells with generation
- /GRSH3N/GRSH3N
- 3 node shell groups
- /GRSH3N/MAT
- Material
- /GRSH3N/PART
- Part
- /GRSH3N/PROP
- Property
- /GRSH3N/SH3N
- 3 node shell numbers
- /GRSH3N/SUBMODEL
- Submodel
- /GRSH3N/SUBSET
- Subset
- A 3 node shell group is a set of 3 node
shells (only). It can be defined explicitly by a list of:
- 3 node shell ID
- entering a first and last 3 node shell ID range which defines the group
- subsets or parts (all 3 node shells belonging to the listed subsets/parts are included)
- submodels (all 3 node shells defined in the listed submodels are included)
- property sets or materials (all 3 node shells having those Property Type's/MID's are included)
- a box (all 3 node shells within a defined box are included)
- The 3 node shell groups are used to define sections, TH output.
- The 3 node shell groups cannot contain 4 node shell elements (use /GRSHEL instead).
