/GRTRUS/GENE
Block Format Keyword Generate a group of truss elements by listing the first and last element IDs in the range.
For each list, enter first node and last node (any number of lists may be input, up to 5 per Line). All nodes between first_ID and last_ID are selected.
/GRTRUS/GENE/grtrus_ID/unit_ID
grtrus_title
first_ID1 last_ID1 first_ID2 last_ID2 first_ID3 last_ID3 first_ID4 last_ID4 first_IDn last_IDn
grtrus_ID Truss group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grtrus_title Truss group title
first_ID1, last_ID1,...first_IDn, last_IDn List of first and last truss identifiers
(Integer)
