/INITRUSS/FULL
Block Format Keyword Describes the initial state for truss elements. All values defined in this card will be applied at the beginning on the computation.
/INITRUSS/FULL/unit_ID
truss_ID   prop_type
EINT F AREA ε p
unit_ID Optional unit identifier
(Integer, maximum 10 digits)
spring_ID Element identifier
(Integer)
prop_type Property set
(Integer)
EINT Total internal energy
(Real)
[ J ]
F Truss element normal force
(Real)
[ N ]
AREA Cross-sectional area of the truss
(Real)
[ m 2 ]
ε p Plastic strain
(Real)
