An explicit is solved by calculating results in small time increments or time steps. The size of the time step depends
on many factors but is automatically calculated by Radioss.
Composite materials consist of two or more materials combined each other. Most composites consist
of two materials, binder (matrix) and reinforcement. Reinforcements come in three forms, particulate,
discontinuous fiber, and continuous fiber.
Describes orthotropic solid material which use the Tsai-Wu formulation. The materials are 3D orthotropic-elastic,
before the Tsai-Wu criterion is reached. LAW12 is a generalization and improvement of LAW14.
LAW25 is the most commonly used composite material in Radioss. It can be used with shell and solid elements. The two formulations available in LAW25 are the Tsai-Wu and CRASURV formulations.
Radioss has two material laws for modeling fabrics LAW19 and LAW58. LAW19 is an elastic orthotropic material and must be used with /PROP/TYPE9. LAW58 is hyperelastic anisotropic fabric material and must be used with /PROP/TYPE16.
Composite could be modeled with solid or shell element. Depending on the element type, the following properties can
be used in Radioss to model a composite.
Optimization in Radioss was introduced in version 13.0. It is implemented by invoking the optimization capabilities of
OptiStruct and simultaneously using the Radioss solver for analysis.
are 3D orthotropic-elastic, before the Tsai-Wu criterion is reached.
LAW14.
Elastic Phase
Both material laws require Young's modulus, shear modulus and Poisson ratio (9 parameters) to
describe the material orthotropic in elastic phase. Figure 1. (1)
Stress Damage
Stress limits (in tensile/compression) are requested for damage.
These stress limits could be observed from a tensile test in 3 related
directions. Figure 3.
Once stress limit is reached, then damage to material begins (stress reduced with damage
parameter ). If Damage ()
reaches D=1, then stress is reduced to 0. Figure 4.
Tsai-Wu Yield Criteria
In LAW12 (3D_COMP), the Tsai-Wu yield criteria is:(2)
The 12 coefficients of the Tsai-Wu criterion could be determined using the yield
stress from the following tests:
Tensile/Compression Tests
Longitude tensile/compression (in direction 1): Figure 5. (3)
(4)
Transverse tensile/compression (in direction 2): Figure 6. (5)
(6)
Transverse tensile/compression (in direction 3): Figure 7. (7)
(8)
Then the interaction coefficients can be calculated as:(9)
(10)
(11)
Shear Tests
Shear in plane 1-2 test: Figure 8. and can result from the sample tests below: Figure 9. (12)
Shear in plane 1-3 Figure 10. and can result from the sample tests below: Figure 11. (13)
Shear in plane 2-3: Figure 12. (14)
The parameters shown below in LAW12 and LAW14
are requested to calculate the Tsai-Wu criteria: Figure 13.
The yield surface for Tsai-Wu is . As long as , the material is in the elastic phase. Once , the yield surface is exceeded and the material is
in nonlinear phase.
In these two material laws, the following factors could also be considered for the
yield surface.
Plastic work with parameter B and
n
Strain rate with parameter and c. (15)
Then the yield surface will be .
Material will be in elastic phase, if
Material will be in nonlinear phase, if
This yield surface will be limited with (), where is the maximum value of the Tsai-Wu criterion limit.
Depending on parameter B, n, c and , the yield surface is between 1 and
. Figure 14. Tsai-Wu Yield Criteria in 1-2 Plane
