Processing math: 100%
/MAT/LAW64 (UGINE_ALZ)
Block Format Keyword This law describes the Ugine & Alz trip steel material. This material law can be used only with shell elements.
/MAT/LAW64/mat_ID/unit_ID or /MAT/UGINE_ALZ/mat_ID/unit_ID
mat_title
ρi
E ν Cp
D n Md V0 Vm
fct_ID0 fct_ID1 Fscale0 Fscale1 T0
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
mat_title Material title.
ρi Initial density.
(Real)
[kgm3]
E Initial Young's modulus.
(Real)
[Pa]
ν Poisson's ratio.
(Real)
Cp Specific heat capacity.
Default = 1030 (Real)
[JkgK]
D Material parameter 1.
(Real)
n Material parameter 2.
(Real)
Md Limit martensite transformation temperature.
(Real)
[K]
V0 Material parameter.
(Real)
Vm Constant martensite fraction for second yield stress function 0 < Vm ≤ 1.
(Real)
fct_ID0 Yield stress function identifier for 0 martensite fraction.
(Integer)
fct_ID1 Yield stress function identifier for Vm martensite fraction.
(Integer)
Fscale0 Scale factor for yield function for fct_ID0.
(Real)
[Pa]
Fscale1 Scale factor for yield function for fct_ID1.
(Real)
[Pa]
T0 Initial temperature.
(Real)
[K]
Example (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW64/1/1
Steel
#              RHO_I
              7.8E-9
#                  E                  Nu                  Cp
              210000                  .3           460000000
#                  D                   n                  Md                  V0                  Vm
                   4                 3.5                 356                  .2                  .6
# func_ID0  func_ID1             Fscale0             Fscale1                  T0
         1         2                   1                   1                 323
#-  3. FUNCTIONS:
/FUNCT/1
function_1
#                  X                   Y
                   0                 250
                .001                 350
                  .5                1100
/FUNCT/2
function_2
#                  X                   Y
                   0                 930
                .001                1000
                  .5                1500
#ENDDATA
/END
  1. Martensite fraction:(1)
    Vm(εp,T)=Vmaxm(T)(1e(Dεp)n)
    (2)
    Vmaxm(T)=V0Ln(MdT+1)
    if (3)
    T<Md
    (4)
    Vmaxm(T)=0
    if (5)
    T>Md
  2. Mechanical behavior:
    The yield plastic stress is computed by linear interpolation between two curves fct_ID1 and fct_ID0.
  3. The temperature is computed assuming the adiabatic condition (by default the condition is isothermal with Cp = 1030):(6)
    T=T0+EintρCp(Volume)
    Where, Eint is the internal energy of the element.
