/MONVOL/COMMU (Obsolete)
Block Format Keyword Describes the airbag with communications monitored volume type.
/MONVOL/COMMU/monvol_ID/unit_ID
monvol_title
surf_IDex
Ascalet AscaleP AscaleS AscaleA AscaleD
    μμ Pext T0 Iequi Ittf
γiγi cpai cpbi cpci
Number of injectors
Njet
Define Njet injectors (four lines per injector)
γγ cpa cpb cpc
fct_IDmas Iflow Fscalemas fct_IDT FscaleT sens_ID
Ijet node_ID1 node_ID2 node_ID3
fct_IDPt fct_IDP θθ fct_IDP δδ   FscalePt FscaleP θθ FscaleP δδ
Number of vent holes
Nvent
Define Nvent vent holes membranes (four lines per vent hole membrane)
surf_IDv Avent Bvent Tstop
Tvent ΔPdefΔPdef ΔtPdefΔtPdef fct_IDV FscaleV IdtPdef
fct_IDt fct_IDP fct_IDA   Fscalet FscaleP FscaleA
fct_IDt' fct_IDP' fct_IDA'   Fscalet' FscaleP' FscaleA'
Number of communicating airbags
Nbag
Define NBAG communicating airbags (one line per communicating airbag)
bag_ID surf_IDc ΔPCdefΔPCdef Acom Tcom ΔtPCdefΔtPCdef
monvol_ID Monitored volume identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
monvol_title Monitored volume title
surf_IDex External surface identifier 1
(Integer)
Ascalet Abscissa scale factor for time based functions
Default = 1.0 (Real)
[s][s]
AscaleP Abscissa scale factor for pressure based functions
[Pa][Pa]
AscaleS Abscissa scale factor for area based functions
[m2][m2]
AscaleA Abscissa scale factor for angle based functions
[deg][deg]
AscaleD Abscissa scale factor for distance based functions
[m][m]
μμ Volumetric viscosity
Default = 0.01 (Real)
Pext External pressure
(Real)
[Pa][Pa]
T0 Initial temperature
Default = 295 (Real)
[K][K]
Iequi Initial thermodynamic equilibrium flag.
= 0
The mass of gas initially filling the airbag is determined with respect to the volume at time zero.
= 1
The mass of gas initially filling the airbag is determined with respect to the volume at beginning of jetting.
(Integer)
Ittf Venting time shift flag. Active only when injection sensor is specified.
= 0 or 1
Time dependent porosity curves are not shifted by injection sensor activation time. Tvent and Tstop are ignored.
= 2
Time dependent porosity curves are shifted by Tinj (Tinj defined as the time of the first injector to be activated by the sensor).
= 3
Time dependent porosity curves are shifted by Tinj +Tvent. Venting is stopped at Tinj + Tstop, when Tstop is specified.
γiγi Ratio of specific heats at initial temperature
γi=cpicviγi=cpicvi
(Real)
cpai cpa coefficient in the relation cpi(T)
(Real)
[JkgK][JkgK]
cpbi cpb coefficient in the relation cpi(T)
(Real)
[JkgK2][JkgK2]
cpci cpc coefficient in the relation cpi(T)
(Real)
[JkgK3][JkgK3]
Njet Number of injectors
(Integer)
Nvent Number of vent holes
(Integer)
surf_IDv Vent holes membrane surface identifier 17
(Integer)
Avent If surf_IDv0: scale factor on surface
Default = 1.0
If surf_IDv = 0: surface of vent holes
Default = 0.0 (Real)
[m2][m2] , if surf_IDV = 0
Bvent If surf_IDv0: scale factor on impacted surface.
Default = 1.0
If surf_IDv = 0: Bvent is reset to 0.
Tvent Start time for venting
[s][s]
Tstop Stop time for venting
Default = 1E+30 (Real)
[s][s]
fct_IDT Porosity vs time function identifier
(Integer)
fct_IDP Porosity vs pressure function identifier
(Integer)
fct_IDA Porosity vs area function identifier
(Integer)
FscaleT Scale factor for fct_IDT
FscaleP Scale factor for fct_IDP
FscaleA Scale factor for fct_IDA
γ Ratio of specific heats
γ=CpCvγ=CpCv
(Real)
cpa cpa coefficient in the relation cp(T)
(Real)
[JkgK][JkgK]
cpb cpb coefficient in the relation cp(T)
(Real)
[JkgK2][JkgK2]
cpc cpc coefficient in the relation cp(T)
(Real)
[JkgK3][JkgK3]
fct_IDmas Mass of injected gas vs time function identifier
(Integer)
Iflow Mass vs time function input type flag
= 0
Mass is input
= 1
Mass flow is input
(Integer)
Fscalemas Mass function scale factor
[kg][kg]
fct_IDT Temperature of injected gas vs time function identifier
(Integer)
FscaleT Temperature function scale factor
[K][K]
sens_ID Sensor identifier to start injections
(Integer)
Ijet Jetting flag
= 0
No jetting
= 1
Jetting
(Integer)
node_ID1, node_ID2, node_ID3 Node identifiers N1, N2, and N3 for jet shape definition
(Integer)
fct_IDPt Identifier of the function number defining ΔPtΔPt
(Integer)
fct_IDP θθ Identifier of the function number defining ΔP(θ)ΔP(θ) )
(Integer)
fct_IDP δδ Identifier of the function number defining ΔP(δ)ΔP(δ) )
(Integer)
FscalePt Scale factor for fct_IDPt
[Pa][Pa]
FscaleP θθ Scale factor for fct_IDP θθ
[Pa][Pa]
FscaleP δδ Scale factor for fct_IDP δδ
[Pa][Pa]
ΔtPdefΔtPdef Minimum duration pressure exceeds Pdef to open vent hole membrane
(Real)
[s][s]
fct_IDV Outflow velocity function identifier
(Integer)
FscaleV Scale factor on fct_IDV
[ms][ms]
IdtPdef Time delay flag when ΔPCdefΔPCdef is reached:
= 0
Pressure should be over ΔPCdefΔPCdef during a ΔtPCdefΔtPCdef cumulative time to activate venting.
= 1
Venting is activated ΔtPCdefΔtPCdef after ΔPCdefΔPCdef is reached.
fct_IDt' Porosity vs time when contact function identifier
(Integer)
fct_IDP' Porosity vs pressure when contact function identifier
(Integer)
fct_IDA' Porosity vs impacted surface function identifier
(Integer)
Fscalet' Scale factor for fct_IDt'
FscaleP' Scale factor for fct_IDP'
FscaleA' Scale factor for fct_IDA'
Nbag Number of communicating airbags
(Integer)
bag_ID Airbag identifier 26
(Integer)
surf_IDc Communicating surface identifier
(Integer)
ΔPCdefΔPCdef Pressure difference to open communication surface membrane
(Real)
[Pa][Pa]
Acom Communication surface coefficient
Default = 1.0 (Real)1
Tcom Start time for communication
(Real)
[s][s]
ΔtPCdefΔtPCdef Minimum duration pressure difference exceeds ΔPCdefΔPCdef to open communication surface membrane
(Real)
[s][s]
  1. surf_IDex must be defined using segments associated with 4-nodes or 3-nodes shell elements (possibly void elements).
  2. The volume must be closed and the normals must be oriented outwards.
  3. Abscissa scale factors are used to transform abscissa units in airbag functions, for example:(1)
    F(t)=fct_ID(tAscalet)
    Where, t is the time. (2)
    F(p)=fct_ID(pAscalep)
    Where, p is the pressure.
  4. The initial pressure is set to Pext.
  5. The gas within each communicating chamber should have the same characteristics: γ and cp.
  6. Initial thermodynamic equilibrium is written at time zero (Iequi =0) or at beginning of jetting (Iequi =1), based on the following equation with respect to the volume at time zero, or the volume at beginning of jetting:(3)
    PextV=RM0MiT0
    Where, M0 is the mass of gas initially filling the airbag, Mi is the molar mass of the gas initially filling the airbag, and R is the gas constant depending on the units system.(4)
    R=8.314JmoleK
  7. Ratio of specific heats at constant pressure per mass unit cpi of the gas initially filling the airbag is quadratic versus temperature:(5)
    cpi(T)=cpa+cpbi*T+cpci*T2
  8. Gas constant at initial temperature γi must be related to specific heat per mass unit at initial temperature and molar mass of the gas initially filling the airbag with respect to the following relation:(6)
    (γ1)γicpi(To)=RMi
    Where, Mi is the molar mass of the gas initially filling the airbag and R is the gas constant depending on the units system.(7)
    R=8.314JmoleK
  9. The characteristics of the gas initially filling the airbag must be defined (no default) and must be equal for each communicating airbag.
  10. Ratio of specifics at constant pressure per mass unit cpi of the gas is quadratic with regard to the temperature:(8)
    cp(T)=cpa+cpb*T+cpc*T2
  11. Gas constant at initial temperature γ must be related to specific heat per mass unit at initial temperature and molar mass of the with respect to the following relation:(9)
    (γ1)γcp(To)=RM
    Where, M is the molar mass of the gas and R is the gas constant depending on the units system.(10)
    R=8.314JmoleK
  12. If jetting is used, an additional Δ Pjet pressure is applied to each element of the airbag:(11)
    ΔPjet=ΔP(t)*ΔP(θ)*ΔP(δ)*max(n*m,0)
  13. With m being the normalized vector between the projection of the center of the element upon segment (node_ID1 and node_ID3) and the center of the element; θ the angle between vectors MN2 and m (in degrees), δ the distance between the center of the element and its projection upon segment (node_ID1 and node_ID3).
    The projection of a point upon segment (node_ID1 and node_ID3) is defined as the projection of the point in direction MN2upon the line (node_ID1and node_ID3) if it lies inside the segment (node_ID1 and node_ID3 ). If this is not the case, the projection of the point upon segment (node_ID1 and node_ID3) is defined as the closest node node_ID1 or node_ID3.
    clip0087
    Figure 1. Dihedral Shape of the Jet
    with M between of N1and N3
  14. If node_ID3= 0, node_ID3 is set to node_ID1 and the dihedral shape is reduced to a conical shape.
  15. Vent hole membrane is deflated if T > Tvent or if the pressure exceeds Pdef during more than ΔtPCdef .
  16. If fct_IDV = 0: isenthalpic outflow is assumed, else Chemkin model is used and outflow velocity is:(12)
    ν=FscaleVfct_IDV(PPext)
    • Isenthalpic model
      Venting or the expulsion of gas from the volume, is assumed to be isenthalpic.
      The flow is also assumed to be unshocked, coming from a large reservoir and through a small orifice with effective surface area, A.
      Conservation of enthalpy leads to velocity, u at the vent hole. The Bernouilli equation is then written as:
      (monitored volume) γγ1Pρ=γγ1Pextρvent+u22 (vent hole)
      Applying the adiabatic conditions:
      (monitored volume) Pργ=Pextρventγ (vent hole)
      Where, P is the pressure of gas into the airbag and ρ is the density of gas into the airbag.
      Therefore, the exit velocity is given by:(13)
      u2=2γγ1Pρ(1(PextP)γ1γ)
      For supersonic flows the outlet velocity is determined as described in 10.4.4.1 of the Theory Manual.
      The mass out flow rate is given by:(14)
      ˙mout=ρvent*vent_holes_surface*u=ρ(PextP)1γ*vent_holes_surface*u
      The energy flow rate is given by:(15)
      ˙Eout=˙moutEρV=(PextP)1γ*vent_holes_surface*uEV
      Where, V is the airbag volume and E is the internal energy of gas into the airbag.
    • Chemkin model(16)
      ˙mout=vent_holes_surface*Fscalev*fct_IDv(P=Pext)*ρ
      Where, ρ is the density of the gas within the airbag.
  17. If surf_IDv0 (surf_IDv is defined). (17)
    vent_holes_surface=Avent*fct_IDA(A)*fct_IDt(t)*fct_IDP(PPext)
    Where, A is the Area of surface surf_ID.
  18. If surf_IDv = 0 (surf_IDv is not defined).(18)
    vent_holes_surface=Avent*fct_IDt(t)*fct_IDP(PPext)
  19. Functions fct_IDt and fct_IDP are assumed to be equal to 1, if they are not specified (null identifier).
  20. Function fct_IDA is assumed as the fct_IDA(A) = A, if it is not specified.
  21. In order to use porosity during contact, flag IBAG must be set to 1 in the interfaces concerned (Line 3 of interface Type 5 and Type 7). If not, the nodes impacted into the interface are not considered as impacted nodes in the previous formula for Aimpacted and Anon_impacted.
  22. Vent holes surface is computed as follows:
    If surf_IDv = 0 (surf_IDv is not defined). (19)
  23. If surf_IDv0 (surf_IDv is defined). (20)
    vent_holes_surface=Avent*Anon_impacted*fct_IDt(Anon_impacted/A0)*fct_IDP(PPext)+Bvent*Aimpacted*fct_IDt(Aimpacted/A0)*fct_IDP(PPext)
    with impacted surface:(21)
    Aimpacted=eSventnc(e)n(e)Ae
    and non-impacted surface:(22)
    Anon_impacted=eSvent(1nc(e)n(e))Ae
    Where for each element e of the vent holes surf_IDv, nc(e) means the number of impacted nodes among the n(e) nodes defining the element.
    Figure 2. From Nodes Contact to Impacted/Non-impacted Surface
  24. Functions fct_IDt' and fct_IDP' are assumed to be equal to 1, if they are not specified (null identifier).
  25. Function fct_IDA' is assumed as the fct_IDA'(A) = A, if it is not specified.
  26. All communicating airbags bag_ID should be type COMMU monitored volumes.
  27. Only the communication from the monitored volume monvol_ID to airbag bag_ID is considered (outwards communication).
  28. When defining venting, there are some limitations concerning the definition of airbag surface and surface venting:
    • The airbag external surface should be built only from shells and 3-nodes shell elements.
    • The airbag external surface can not be defined with option /SURF/SEG (nor with option /SURF/SURF if a sub-surface is defined with option /SURF/SEG).
    • Same restriction applies to vent hole surface.
    • Shells and 3-nodes shell elements included in vent hole surface have to be included also in external surface.
    • Shells and 3-nodes shell elements included in communicating surface have to also be included in external surface.
  29. Communication surface is open if T > Tvent or if the pressure exceeds ΔPCdef during more than ΔtPCdef .
