/MONVOL/PRES
Block Format Keyword Describes the pressure load curve monitored volume type.
/MONVOL/PRES/monvol_ID/unit_ID
monvol_title
surf_IDex
Ascalet
fct_ID Fscale   Itypfun
monvol_ID Monitored volume identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
monvol_title Monitored volume title
surf_IDex External surface identifier.
(Integer)
Ascalet Abscissa scale factor for time based functions.
(Real)
[s]
fct_ID Load curve identifier for relative pressure Prel(V0V) MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGqbWaaSbaaSqaaiaadkhacaWGLbGaamiBaaqabaGcdaqadiqaamaalaaabaGaamOvamaaBaaaleaacaaIWaaabeaaaOqaaiaadAfaaaaacaGLOaGaayzkaaaaaa@3E7C@ or Prel(t) MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGqbWaaSbaaSqaaiaadkhacaWGLbGaamiBaaqabaGcdaqadiqaaiaadshaaiaawIcacaGLPaaaaaa@3CBF@ depending on Itypfun input.
(Integer)
Fscale Load curve scale factor for relative pressure.
Default = 1.0 (Real)
[Pa]
Itypfun Argument of the relative pressure function flag.
=0
Pressure depends on relative volume.
= 1
Pressure depends on time.
(Integer)
  1. The relative pressure is defined as, Prel = pressure inside of monitored volume - atmospheric pressure.
  2. surf_IDex must be defined using segments associated with 4- or 3-nodes shell elements (possibly void elements) and not with /SURF/SEG.
  3. The volume must be closed and the normals must be oriented outwards.
  4. Abscissa scale factors are used to transform abscissa units in airbag functions, for example:(1)
    F(t)=fct_IDt=f(tAscalet)
    Where,
    t MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiDaaaa@36EF@
    Time
    (2)
    F(P')=fct_IDP=f(PrelAscaleP) MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGgbGaciikaiaadcfacaGGNaGaaiykaiabg2da9iaadAgacaWGJbGaamiDaiaac+facaWGjbGaamiramaaBaaaleaacaWGqbaabeaakiabg2da9iGacAgadaqadaqaceaaooWaaSaaaeaacaWGqbWaaSbaaSqaaiaadkhacaWGLbGaamiBaaqabaaakeaacaWGbbGaam4CaiaadogacaWGHbGaamiBaiaadwgadaWgaaWcbaGaamiuaaqabaaaaaGccaGLOaGaayzkaaaaaa@4FCA@
    Where,
    Prel MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGqbWaaSbaaSqaaiaadkhacaWGLbGaamiBaaqabaaaaa@3A31@
    Relative pressure
