Run Options
The Radioss solution process can be launched from the HyperWorks Solver Run Manager, the command line using a submission script, or from HyperMesh.
From HyperWorks Solver Run Manager
The HyperWorks Solver Run Manager is the easiest way to launch a Radioss computation.
Figure 1. HyperWorks Solver Run Manager
On Windows, the Solver Run Manager can be launched using
.The HyperWorks Solver Run Manager help describes how to manage multiple solver runs using a queue, schedule a delay when launching a run, stop a job, and select run options from a graphical menu.
- Linux
- <install_dir>/altair/scripts/radioss
-gui
- Windows
- <install_dir>/hwsolvers/scripts/radioss.bat
-gui
Input Filename
- By default, all the Starter and Engine files in the directory of the input file will be ran. Multiple Engine files can easily be ran by placing them in the same directory as the Starter file.
- If an Engine file is selected, then the Engine file will be ran followed by any other Engine files in the directory.
- If the
-onestep
option is used, only the selected input file will be ran. Only the Starter is ran if the input file is a Starter file and only the Engine file is ran if the input file is an Engine file.
Commonly Used Run Options
Option | Argument | Description |
-onestep |
N/A | Disable auto continuation to next Engine, run only Starter for single file format. |
-nt |
Number of threads | Number of SMP threads per SPMD MPI
domain. (Example: radioss
ROOTname_0000.rad
-np |
Number of SPMD MPI domains | Number of Radioss SPMD MPI
domains. (Example: radioss
ROOTname_0000.rad
All Available Run Options
-mpipath {C:/Program Files/MPI}
File paths on Windows may use backward "\" or forward slash "/", but must be within quotes when using a backslash "\".
Option | Argument | Description | Available Platforms |
-altver |
Suffix for alternate solver version. | All Platforms | |
-appfile |
N/A | Spec file with some MPI for SPMD run. | All Platforms |
-args |
Extra arguments that
are passed to the solver. Example: |
All Platforms | |
-checkpoint |
N/A | Run Radioss Engine starting from checkpoint savefile. | All Platforms |
-debug |
1,
2 |
Output scripting debugging information. | All Platforms |
-delay |
Number of seconds | Delays the start of a
Radioss run for the specified
number of seconds. This functionality does not use licenses,
computer memory or CPU before the start of the run (the delay
expires). This option may be used to wait for any
computing resources which are currently usable but are not
yet freed by the previous run. If the previous run crashed,
then the license may still be locked by the license server
depending on the timeout value, or the memory may still be
reserved by the Operating System.
Note:
All Platforms |
-dylib |
FILE |
Set name to the dynamic library for Radioss User Subroutines | All Platforms |
-hostfile |
TEXT
FILE |
Text file that list the hosts and number of cores for a multi-computer (node) run. Refer to MPI document for exact format. | All Platforms |
-mpi |
i ,
pl , ms |
Specify which MPI
software is used for multiprocessor (SPMD) run.
Note: An argument for
-mpi is
optional. If an argument is not specified, Intel MPI is
used by default. |
Not all platforms support all MPI software. |
-mpipath |
DIRECTORY |
Specify the path where
mpirun is located.(HyperWorks includes the MPI software so this typically is not needed). |
All Platforms |
-noh3d |
N/A | Do not generate h3d file from Radioss animation files when the simulation has ended. | All Platforms |
-norst |
N/A | Remove all restart (*.rst) files after the simulation has ended. | All Platforms |
-np
or -nspmd |
domains. Example: |
All Platforms |
-nt
or -nthread |
Number of thread | Number of SMP threads
per SPMD MPI domain. Example: |
All Platforms |
-nt_r2r |
Number of cpu threads for multi-domain process. | All Platforms | |
-onestep |
N/A | Disable auto continuation to next Engine or mod file, run only Starter for single file format. | All Platforms |
-radfiles |
N/A | List all files in the current folder with detected types (Starter/Engine/mod). | All Platforms |
-radopt |
.radopt File | Option to run Radioss optimization with OptiStruct. It specifies to request an
optimization run for an Radioss
input deck. Note: The Radioss Starter and input files
supporting the optimization input should be available in the
same directory as the <name>.radopt
file.
Refer to Design Optimization for more information. |
All Platforms |
-sp |
N/A | Specify to run a single precision version of Radioss. | All Platforms |
-v |
Required version of
solver if multiple are installed. If not specified, newest
version installed is used. Example: |
All Platforms |
Solver Control
From a HyperWorks Script
Launch Radioss from a command line using the script included in HyperWorks.
This script should be used when running Radioss on high-performance computing cluster via a job scheduler because many environment variables are already defined so it simplifies the setup. All the options available in the HyperWorks Solver Run Manager can be used from the command line.
<install_dir>/altair/scripts/radioss "filename" -option argument
<install_dir>\hwsolvers\scripts\radioss.bat "filename" -option argument
The script options are described in All Available Run Options.
From HyperMesh
When creating a Radioss finite element model in HyperMesh, the simulation can be ran directly in HyperMesh by going to the Radioss panel.
<hostname>:0.0
. If
this is different from the DISPLAY setting for HyperMesh, 25/38 HyperWorks
units (in addition to the 21 HyperWorks units being
used for HyperMesh) will be checked out. To avoid
the checking out of additional units, be sure that the DISPLAY is set to
<hostname>:0.0
before starting HyperMesh.Run Executables Directly
The Radioss executables can be executed directly, but various environment variables need to be defined.
It is therefore recommended and easier to utilize the Radioss script included in HyperWorks when launching jobs on a computer server. If it is still necessary to run the executables directly, the following environment variables must be set.
RADFLEX_PATH
=<install_dir>/hwsolvers/common/bin/<platform>/
RAD_H3D_PATH
<install_dir>/hwsolvers/radioss/lib/<platform>/
HWSOLVERS_TEMPLEX
ABF_PATH
=<install_dir>/hwsolvers/radioss/bin/<platform>/
- Linux
KMP_STACKSIZE
=400m- Windows
KMP_STACKSIZE
=400m
- Windows Only
- Update environment variable,
PATH
=%PATH%;\
<install_dir>\hwsolvers\common\bin\win64;\ <install_dir>\hwsolvers\radioss\lib\win64
- Linux Only
LD_LIBRARY_PATH
=<install_dir>/hwsolvers/common/bin/linux64/:<install_dir>/hwsolvers/radioss/lib/linux64
The Radioss executables can be found in <install_dir>\hwsolvers\radioss\bin\<platform>\.
./s_<version>_<platform> –i <arguments> <prefix>_0000.rad
./e_<version>_<platform> –i <arguments> <prefix>_0001.rad
Refer to the Advanced Installation Guide for information on using Radioss with MPI software.
Starter and Engine Exit Codes
The Starter and Engine provide exit codes that can be used by scripts.
- 0
- Normal termination.
- 2
- Model or computation error.
- 3 or 128 + Signal number
- Process failure (core dump, segmentation fault).
’ command in a Linux shell
script.#!/bin/bash
s_2019.1_linux64 –input [Starter_input]_0000.rad –np 96
Exit_code=$?
echo $Exit_code
errorlevel
" variable in a
script.s_2019.1_win64.exe –input [Starter_input]_0000.rad –np 96
echo %errorlevel%
Starter Command Line Arguments
The Radioss Starter supports the following command line arguments.
Argument | Short Form | Description |
-help |
-h |
Print help message |
-version |
-v |
Print Radioss release information |
-input
[FILE] |
-i |
Set Radioss Starter input file |
-nspmd
[INTEGER] |
-np |
Set number of SPMD domains |
-nthread
[INTEGER] |
-nt |
Set number of threads per SPMD domains |
-notrap |
Disable error trapping | |
Option to check the model. Disable domain decomposition and restart file writing. | |
Defines the output file directory for all files created. |
-help Argument
Prints help information on the command line arguments.
Radioss Starter exits after the printout.
-version Argument
Prints Radioss release information.
- Radioss title
- Radflex name
- Version to use
- Build information (date, time of build and build tag)
-input [FILE] Argument
Sets the Radioss Starter input file.
The FILE argument must be a Radioss Starter input
file with the following format: [ROOTNAME]_[RUN NUMBER].rad
where:
ROOTNAME
is the dataset rootname
RUN NUMBER
is the run number expressed in four numbers.
e.g. CRA2V51_0000.rad
ROOTNAME: CRA2V51
RUN NUMBER: 0000
ROOTNAME
andRUN NUMBER
are extracted from the input file.- The dataset
ROOTNAME
andRUN NUMBER
settings in /BEGIN are ignored when the-input
command option is used. - If the file name doesn't have the correct format, the file is rejected.
- The file is open. Standard input is no longer used.
- If
-input
is not set, Radioss Starter opens standard input to read input.
[user@machine]$ ./s_2019_linux64 -input CRA2V51_0000.rad
** RADIOSS STARTER 2019 **
** Non-linear Finite Element Analysis Software **
** from Altair Engineering, Inc. **
** Linux 64 bits, Intel compiler, Intel MPI **
** Build tag: 0479348_2413000 **
** COPYRIGHT (C) 1986-2019 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
.. BLOCK FREE FORMAT
CRA2V51
.. CONTROL VARIABLES
.. UNITS SYSTEM
.. MATERIALS
.. NODES
.. PROPERTIES
.. 3D SHELL ELEMENTS
.. SUBSETS
.. ELEMENT GROUPS
.. NODE GROUP
.. BOUNDARY CONDITIONS
.. INITIAL VELOCITIES
.. ELEMENT GROUPS
.. ADDED MASSES
.. ELEMENT BUFFER INITIALIZATION
.. GEOMETRY PLOT FILE
.. RESTART FILE
NORMAL TERMINATION
0 ERROR(S)
0 WARNING(S)
PLEASE CHECK OUTPUT FILE FOR FURTHER DETAILS
[user@machine]$
-nthread [SMP THREAD NUMBER] Argument
Sets the number of SMP threads per SPMD domain. Each SPMD domain will be computed using a multi-threaded process composed of SMP THREAD NUMBER.
Where, SMP THREAD NUMBER: INTEGER is the number of SMP threads per SPMD domain.
Example:
[user@machine]$ ./s_2019_linux64 -nthread 2
- If the SMP THREAD NUMBER value is not properly set, Radioss Starter stops with error message.
- If
-nthread
is set, the number of threads set in /SPMD input card is ignored. /SPMD card can be omitted if other parameters are kept as default settings. - The total number of processes used for the Radioss Engine computation will be equal to SPMD DOMAIN NUMBER * SMP THREAD NUMBER.
-notrap Argument
Disables the trapping error of Radioss Starter.
By default, in case of error, Radioss Starter will display an error
message that corresponds to the error occurred and stop properly. If
-notrap
is used, Radioss Starter
will continue and potentially core dumps where the error occurs. This behavior is
sometimes helpful to trace the error with external tools.
General Behavior, Error Handling
-version
-help
-nspmd
,-input
,-nthread
,-notrap
-nspmd
-nthread
, -notrap
and
-input
can be used together; and the order does not
matter.
- Missing argument to
-input
or-nspmd
or-nthread
-input
argument is not a Radioss file format-nspmd
or-nthread
argument are not an integer value- unknown command line argument used
An error message is printed out with the -help
printouts.
-check Argument
Option to stop the Starter after model check.
The domain decomposition calculation and writing of the restart files (.rst) is not done. This reduces the time to run for the Starter model to run when doing a model check.
-outfile=[output path] Argument
The Starter writes all output and restart files in the defined output path.
The output path can be absolute or relative. If there is a space in the output path then, quotes must be used in the path. On Windows, either “/” or “\” can be used between directories.
s_2020.1_linux64 -i TENSI36_0000.rad -outfile=/storage/files/run1
s_2020.1_linux64 -i TENSI36_0000.rad -outfile="../my directory"
s_2020.1_linux64 -i TENSI36_0000.rad -outfile="/storage/files/my directory"
s_2020.1_win64.exe -i TENSI36_0000.rad -outfile=c:\storage\files\run1
s_2020.1_win64.exe -i TENSI36_0000.rad -outfile="../my directory"
s_2020.1_win64.exe -i TENSI36_0000.rad -outfile="c:/storage/files/my directory"
Engine Command Line Argument
Radioss Engine HMPP executables are available (as of version 11.0) with MPI and are fully Hybrid capable mixing SPMD and SMP parallelization.
Simplified executables also exist, which are only SMP capable but do not require MPI.
To distinguish easily between these two types of executables, MPI executables have a _mpp suffix.
- For binaries compiled with MPI, they need to be run through the
mpirun
command. The general form is as follows:mpirun [list of mpirun option] engine_executable_mpp [list of engine option]
Note: The list ofmpirun
options depends on the MPI vendor. Refer to the MPI documentation. - For binaries compiled without
MPI:
engine_executable [list of engine option]
Note: The list of Radioss Engine options is the same for both types of executables.
-help |
-h |
-version |
-v |
-input
[FILE] |
-i |
Set Radioss Engine input file |
-nthread
[INTEGER] |
-nt |
Set Number of SMP threads per SPMD domain |
-notrap |
-norst |
Disable restart *.rst file writing during and at the end of the computation | |
-help Argument
Radioss Engine exits after the printout.
-version Argument
- Radioss title
- Radflex name
- Version to use
Sets the Radioss Engine input file.
The FILE argument must be a Radioss Engine input
ROOTNAME
is the dataset rootnameRUN NUMBER
ROOTNAME
andRUN NUMBER
ROOTNAME
andRUN NUMBER
settings in /RUN are ignored, when the -input command option is used. - If the file name doesn't have the correct format, the file is rejected.
- If -input is not set, Radioss Engine opens standard input to read input.
[user@machine]$ mpirun -np 4 ./e_2019_linux64 impi -nt 2 -input CRA2V51_0001.rad
** RADIOSS ENGINE 2019 **
ROOT: CRA2V51 RESTART: 0001
NUMBER OF HMPP PROCESSES 8
17/10/2008
NC= 0 T= 0.0000E+00 DT= 1.7916E-03 ERR= 0.0% DM/M= 0.0000E+00
ANIMATION FILE: CRA2V51A001 WRITTEN
NC= 100 T= 1.7826E-01 DT= 1.7700E-03 ERR= 0.0% DM/M= 0.0000E+00
NC= 13700 T= 1.9871E+01 DT= 1.4032E-03 ERR= -1.2% DM/M= 0.0000E+00
** CPU USER TIME **
#PROC CONT.SORT CONT.F ELEMENT MAT KIN.COND INTEGR. I/O TASK0 ASSEMB RESOL
1 .0000E+00 .0000E+00 .1144E+02 .2910E+01 .7000E-01 .5600E+00 .3100E+00 .5000E+00 .3700E+00 .1364E+02
2 .0000E+00 .0000E+00 .1102E+02 .2870E+01 .7000E-01 .5600E+00 .0000E+00 .0000E+00 .3300E+00 .1364E+02
ELAPSED TIME : 7.79 s
RESTART FILE: CRA2V51_0001_0000.rst WRITTEN
NORMAL TERMINATION
TOTAL NUMBER OF CYCLES: 13793
[user@machine]$
[user@machine]$ mpirun -np 4 ./e_2019_linux64 impi -nthread 2 -input CRA2V51_0001.rad
- If the INTEGER value is not properly set, the Radioss Starter stops with error message.
- If
-nthread
is set, the number of threads defined in the Starter run (/SPMD input card,-nthread
command line) or previous Engine run is ignored. - The environment variable OMP_NUM_THREADS can also be used to change the number of threads.
-nthread
remains prior to OMP_NUM_THREADS. - For performance reason, it is recommended to use OMP_NUM_THREADS instead of
-nt
. This informs the system of the true number of threads used. - The total number of processes used for the Radioss Engine computation will be equal to SPMD DOMAIN NUMBER * SMP THREAD NUMBER.
-version
-help
-input
,-nthread
,-notrap
The argument order in the command line does not matter.
-input
or-nthread
-input
argument is not a Radioss file format-nthread
argument is not an integer
An error message is printed with the -help
printouts.
MPI and Radioss Options Coherency
The -nspmd
value (or Nspmd field of
/SPMD Starter input card) must match the mpirun -np
value.
If this is not the case, Radioss Engine will stop with an
appropriate error message.
[user@machine]$ ./s_2019_linux64 -nspmd 4 -input CRA2V51_0000.rad
[user@machine]$ mpirun -np 2 ./e_2019_linux64 impi -input CRA2V51_0001.rad
THE REQUIRED NUMBER OF MPI PROCESSES DOES NOT MATCH MPIRUN
PLEASE, RUN WITH THE PROPER NUMBER OF MPI PROCESSES
REQUIRED (NSPMD) = 4
AVAILABLE (mpirun -np) = 2
E R R O R T E R M I N A T I O N
TOTAL NUMBER OF CYCLES : 0
[user@machine]$ mpirun -np 4 ./e_2019_linux64 impi -input CRA2V51_0001.rad
-notrap Argument
Add this option to force core dump.
This is a useful option to get call stack traceback.
-norst Argument
Option to disable restart *.rst file writing during and at the end of the computation.
This makes the Engine run faster because of the reduction in files written.
The Engine writes all output and restart files in the defined output path.
e_2020.1_linux64 -i TENSI36_0000.rad -outfile=/storage/files/run1
e_2020.1_linux64 -i TENSI36_0000.rad -outfile="../my directory"
e_2020.1_linux64 -i TENSI36_0000.rad -outfile="/storage/files/my directory"
e_2020.1_win64.exe -i TENSI36_0000.rad -outfile=c:\storage\files\run1
e_2020.1_win64.exe -i TENSI36_0000.rad -outfile="../my directory"
e_2020.1_win64.exe -i TENSI36_0000.rad -outfile="c:/storage/files/my directory
