/SURF/ELLIPS
Block Format Keyword Describes the hyper-ellipsoid surface definition.
/SURF/ELLIPS/surf_ID/unit_ID
surf_title
skew_ID n
Xc Yc Zc
a b c
surf_ID Surface identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
surf_title Surface title
skew_ID Skew identifier defining the initial orientation of the surface
(Integer)
n Degree of the hyper-ellipsoid
Default = 2 (Integer)
Xc Center coordinate
(Real)
Yc Center coordinate
(Real)
Zc Center coordinate
(Real)
a Semi-axis length
(Real)
b Semi-axis length
(Real)
c Semi-axis length
(Real)
  1. All nodes must belong to a shell element, a brick element or a triangular shell element.
  2. A surface cannot be defined using Madymo surfaces.
  3. A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
  4. The equation of the hyper-ellopsoid is:
    (1)
    | x x c a | n + | y y c b | n + | z z c b | n = 1
  5. A hyper-ellipsoid can only be a master surface of /INTER/TYPE14.
  6. Input format for MDELLIPS, see /SURF/MDELLIPS.
