General Purpose Contact (TYPE5)
This interface is used to simulate the impact between a master surface and a list of slave nodes., as shown in Figure 1.
The penetration is reduced by the penalty method.
Another method is possible: Lagrange multipliers. But spatial distribution force is not smooth and induces hourglass deformation.
- Simulation of impact between beam, truss and spring nodes on a surface.
- Simulation of impact between a complex fine mesh and a simple convex surface.
- A replacement for a rigid wall.
Limitations
- The master segment normals must be oriented from the master surface towards the slave nodes.
- The master side segments must be connected to solid or shell elements.
- The same node is not allowed to exist on both the master and slave surfaces.
- In certain situations, the search algorithm does not identify the correct node to surface impacts.
Computation Algorithm
The computation and search algorithms used for TYPE5 are the same as for TYPE3. Refer to Computation Algorithm.
Interface Stiffness
When two surfaces contact, a massless stiffness is introduced to reduce the penetration's nodes of the other surface into the surface.
The nature of the stiffness depends on the type of interface and the elements involved.
The introduction of this stiffness may have consequences on the time step, depending on the interface type used.
For a TYPE5 interface, the spring stiffness K is determined by master and slave sides. The stiffness scaling factor default value (and recommended value) is 0.2.
For a soft master surface material and stiff slave surface, the stiffness scaling factor should be increased by the elastic modulus ratio of the two materials.
The calculation of the spring stiffness' is the same as in a TYPE3 interface.
If a segment is a shell as well as the face of brick element, the shell stiffness is used.
- s
- Stiffness scaling factor. Default is 0.2.
- K1
- Surface 1 Stiffness
- K2
- Surface 2 Stiffness
- K
- Overall interface spring stiffness
The scale factor, s, may have to be increased if:
K1<<K2 or K2<<K1
The calculation of the spring stiffness for each surface is determined by the type of elements.
For example:
K1=110K2 implies K=s11K2 or K=10s11K1.
Shell Elements
For more information, refer to Shell Element.
Brick Elements
For more information, refer to Brick Element.
Combined Elements
For more information, refer to Combined Elements.
Interface Friction
TYPE5 interface allows sliding between contact surfaces.
Coulomb friction between the surfaces is modeled. The input card requires a friction coefficient. No value (default) defines zero friction between the surfaces.
The friction computation on a surface is the same as for TYPE3 interface. Refer to Interface Friction.
- Darmstad Law:
(2) μ=C1⋅e(C2V)⋅p2+C3⋅e(C4V)⋅p+C5⋅e(C6V) - Renard Law:
(3) μ=C1+(C3−C1)⋅VC5⋅(2−VC5) if V∈[0,C5]μ=C3−((C3−C4)⋅(V−C5C6−C5)2⋅(3−2⋅V−C5C6−C5)) if V∈[C5,C6]μ=C2−11C2−C4+(V−C6) if V≥C6
- C1=μs,C2=μd
- C3=μmax,C4=μm:min
- C5=Vcr1,C6=Vcr2
Where, the coefficient a depends on the Ifiltr flag value.
Interface Gap
Refer to Interface Gap for TYPE3 interface.
Interface Algorithm
- Determine the closest master node.
- Determine the closest master segment.
- Check if the slave node has penetrated the master segment.
- Calculate the contact point.
- Compute the penetration.
- Apply forces to reduce penetration.
For more information, refer to Auto Contacts.
Detection of Closest Master Node
The Radioss Starter and Engine use different methods to determine the closest master node to a particular slave node.
- Get the previous closest segment, S0, to node N at time t1.
- Determine the closest node, M1, to node N which belongs to segment S0.
- Determine the segments connected to node M1 (S0, S1, S2 and S3).
- Determine the new closest master node, M2, to node N at time t1. The new master node must belong to one of the segments S0, S1, S2 or S3.
- Determine the new closest master segment (S2, S4, S5 and S6).
- CPUstarter = a x Number of Slave Nodes x Number of Master Nodes
- CPUengine = b x Number of Slave Nodes
Detection of Closest Master Segment
- P1
- Projection of N on plane (M, B1, B2)
- B1 and B2
- Tangential Surface Vectors along segment S1 edges.
- P2
- Projection of N on plane (M, B2, B3)
The same procedure is carried out for all master segments that node M is connected to.
The closest segment is the segment for which A is a minimum.
- All values of A are positive.
- More than one value of A is negative.
Detection of Penetration
Penetration is detected by calculating the volume of the tetrahedron made by slave node N and the master nodes of the corresponding master segment, as shown in Figure 6.
Reduction of Penetration
- K
- Interface spring stiffness
Where, di=Ni(Sc,tc)4∑j=1N2j(Sc,tc)mi
- Ni
- Standard linear quadralateral interpolation functions
- Sc and tc
- Isoparametric coordinates contact point
- Accuracy
- Generality
- Efficiency
- Compatibility
