Coloring compound blocks
By default, all compound blocks are colored cyan. You can selectively change a compound block’s color.
To choose a color for a specific compound block
1.    CTRL+right-click the compound block, or choose Edit > Block Properties and click the compound block.
2.    In the Compound Properties dialog box under Appearance, activate Set Color and click ... to select a color.
3.    Click OK, or press ENTER.
4.    Click OK, or press ENTER when the Compound Properties dialog box appears.
To choose white for all compound blocks
When printing, you may want compound blocks to be printed in white.
1.    Choose Edit > Preferences.
2.    Select the Preferences tab.
3.    De-activate Color Compound Blocks.
4.    Click OK, or press ENTER.
You can also choose specific colors for individual compound blocks. When you do so, the Color Compound Blocks option has no effect on individually colored compound blocks.
