There are many parameters that control the behavior of the algorithm. Each parameter has a default value that is appropriate for most problems. You are not required to take any action to use the default parameter values; however, at times, it may be necessary to set one or more of the parameters to a new value to make Embed more efficient or to make it possible to solve a difficult problem.
