It is possible that a cost function has no minimum or has a flat surface away from the minima. In this case, the global optimizer will get confused and wander aimlessly (how can you run downhill when there is no hill?). If the optimizer appears to run for a long time with little convergence, you should suspect flat spots in your cost function. In such cases, you may have to reformulate the cost function such that it has at least one minimum. A common mistake is to put a limit block just before the cost input. In this case the optimizer will experiment with larger and larger unknown values to no avail. If a limit block is used in the cost function, it must be placed before an integration of total error.
