Creating block hierarchy
Compound blocks let you encapsulate one or more blocks in a single block. With compound blocks, you have more flexibility in constructing and editing your diagrams, especially if they are complex. The top-level blocks display major component connectivity, leaving the underlying levels to describe the logic of each component.
Compound blocks also encourage a modular approach to large model construction by allowing you to design and test functionally independent subcomponents concurrently. Then using the embed block or the File > Add command, you can incorporate each subcomponent back into the large system diagram.
You can have as many levels as you want in a compound block. The number is limited only by your system resources.
If your compound block contains sensitive information, you can restrict access to the block.
