Category: Transforms
The Inverse Clarke Transform block provides a magnitude invariant transformation of orthogonal reference frame components [alpha beta] to 3-phase signals/systems [a b c]. This Clarke transformation is specific to the case where the primary axis of the 3-phase coordinate system is aligned with the primary axis of the orthogonal coordinate system.
The transform is given by:
Diagram name: Inverse Clarke Transform
