Park Transform (Stationary Frame)
park_xform_stat_ref_block
Category: Transforms
The Park Transform (Stationary Frame) block performs a Park’s forward transformation for stator voltages in the stationary reference frame (3 X 3).
The Park Transform (Stationary Frame) block transforms 3-phase signals/systems [a b c] to quadrature, direct and homopolar components [q d o] in the stationary reference frame (rotation angle = 0).
This transformation is given by:
Park Transform stationary equation
Diagram name: Park Transform Stationary Frame
Park’s transformation is used in this example to transform a 3-phase voltage source to DQ frame voltages for use on the DQ frame model.
