Reading audio data from a WAV file
Under Input Data Source, click the WAV File option to display the following dialog box.
File Name: Indicates the name of the WAV file to be used as input. If you do not know the name, click to find the file.
Input Data Source/.WAV File: Indicates that the audio data is read from a WAV file.
Loop: If the simulation range is longer than the length of the audio data, this option allows the audio data to be played over again until the end of the simulation.
Show Icon: Changes the display of the block to .
