Using the Properties dialog box for the OPC Read and OPC Write blocks, you can do the following:
• Configure group properties
• Select an item from the server
See Also:
Configuring group properties
Selecting the item from the server
Using the Status information to fine-tune your simulation
Viewing item properties
