In designing each compensator, the following system characteristics hold true:
•LM = Log magnitude, base 10
•Cross-over frequency of open-loop Bode
LM plot
• Phase margin of open-loop Bode
phase plot
• Time constant, s
• Damping ratio
The open-loop Bode frequency response can be used to approximate closed-loop system behavior, provided the open-loop frequency response satisfies three conditions:
• The gain at low frequencies is relatively high for low steady-state errors
• The gain at high frequencies is relatively low for disturbance attenuation
• The slope of the Bode plot is approximately
When the above conditions are approximately satisfied, the following correlations are valid:
