Creates channel(s) to measure temperature with a built-in sensor of a terminal block or device.
Refer to the National Instruments NI-DAQmx C Reference Help file for detailed descriptions of these options, under NI-DAQmx C Functions > Channel Configuration/Creation > Create Analog Input Channels > DAQmxCreateA\TempBuiltInSensorChan.
Units: Indicates the units to use to return the measurement.
