The Altair Embed product family includes Basic and Professional Editions.
Feature |
Embed Basic Edition |
Embed Professional Editions | |
Embed |
Embed Simulation-Only (SE) | ||
Limits block diagrams to 100 blocks |
P |
Drag-and-drop block diagram construction |
P |
P |
P |
Continuous, discrete, and hybrid simulations |
P |
P |
P |
Conditional execution of subsystems |
P |
P |
P |
Interactive, batch, auto-restart, and single-step execution modes |
P |
P |
P |
Fixed, adaptive, and stiff integration algorithms |
P |
P |
P |
Standard block set with 120+ mathematical, scientific, and engineering blocks |
P |
P |
P |
OpenVision block set |
P |
P |
P |
State Charts block set |
P |
P |
P |
Fixed Point block set |
P |
P |
Digital Motor Control block set |
P |
Toolbox libraries for controls, dynamic systems, electric, electromechanical, eMotor, fixed point, hydraulics, logic, process, quaternion operations, and signal generation |
P |
P |
P |
Analysis and linearization with Bode, root locus, and frequency domain plots |
P |
P |
P |
Constrained parameter optimization |
P |
P |
P |
Visualization with interactive plots and stripCharts, 3D animation, 3D plots, and polar plots |
P |
P |
P |
Data I/O using National Instruments and Measurement Computing boards |
P |
P |
P |
Data I/O with an OPC server |
P |
P |
Data I/O with an RS 232 device |
P |
P |
P |
Data I/O with UDP |
P |
P |
P |
Data I/O with a PCAN USB Controller Area Network (CAN) device |
P |
P |
P |
Code generation |
P |
P |
Arduino Leonardo, Mega 2560, and Uno target support |
P |
P |
ARM-Linux Raspberry Pi Zero, Zero W, 1A+, 1B+, 2B, 3A+, 3B, 3B+, 4B target support |
P |
P |
STMicroelectronics STM32 F0x, F3x, F4x, G0x, G4x, L4x target support |
P |
P |
Texas Instruments ARM Cortex M3, C2000, Delfino, MSP430, Piccolo target support |
P |
P |
Generic MCU target support |
P |
P |
HotLink |
P |
P |
Four special purpose add-on modules extend Embed’s modeling, simulation, and code generation capabilities.
Add-On Module |
Description |
Embed/Core Source Code Library |
Contains pre-compiled functions for core blocks that are not translated into inline code. Target is the PC. Available only for Embed. Not available for academic (EDU) licenses. |
Embed/Target Source Code Library |
Contains pre-compiled functions for target-specific blocks that are not translated into inline code. There is a Target Source Code Library for each target family. Available only for Embed. Not available for academic (EDU) licenses. |
Embed/Digital Power Designer |
Provides high-level blocks for simulation and code generation of power supply and digital power components and controls. Available only for Embed. |
Embed/Comm |
Simulates end-to-end communication systems at the signal level using 200+ communications, signal processing, and RF blocks. Available for Embed SE and Embed. |
