This section describes how to configure the NI-DAQmx blocks. The block options are described in detail in the National Instruments NI-DAQmx C Reference Help file. When you install your National Instruments boards, this help is installed in Program Files/National Instruments/NI-DAQ/Docs/cdaqmx.chm.
