To view the event log, click on the Show Log button in the Properties dialog box for the OPC Read or OPC Write block.
Because each data exchange causes one or two events to appear in the log file, the log will quickly fill. To significantly reduce the number of messages and memory use, activate the Log Errors Only box.
