Batch Mode
HVVH can be run in batch mode with a simple command line syntax using command line argument(s).
Batch Mode
HVVH Batch Mode
Launch.bat –b Session_path.session
Syntax Example
Launch.bat –b FE_Model_Basic_IO_all.session
Solver check run Batch Mode
Launch.bat –b Session_path.session -check run
Syntax Example
Launch.bat –b FE_Model_Basic_IO_all.session -check run
(this is applicable for FE Basic IO, Special case, HC Basic IO)
Interlinking Tabs
Launch.bat –b LinkingOptions.txt
Interlinking Sessions
Launch.bat –b InterLinkingSessionfiles.txt
Session file example
MainTab : {FE Model}
SubTab : {Basic IO}
Number : 1
Begin : 1
    {Solver Type} : {OptiStruct}
     {HW Version} : {2020}
     {Model Checker} : 1
     {Input Files} : { Composite_Wing_cr1.fem}
     {Ouput Directory} : {C:/TEMP2}
End : 1
Linking Options text file example
OPTIONS:
 {CAD} : {0}
 {FE} : {0}
 {CAD-FE} : {0}
 {FE-SOL-RESULT} : {0}
 {CAD-FE-SOL-RESULT} : {1}
Paths:
 {CAD} : LinkingCadTabs.txt
 {FE}  : LinkingFEModelTabs.txt
 {SOL-RESULT} : LinkingSolutionTabs.txt
Linking Session text file example
Sessions:
C:\temp\CAD_CAD_IO.session
C:\temp\CAD_Compare_Versions.session
C:\temp\CAD_CAD__Mesh.session
C:\temp\CAD_FE-FE.session
C:\temp\FE_Model_Model_Setup.session
C:\temp\FE_Model_Keywords_coverage_lsdyna.session
C:\temp\FE_Model_Basic_IO.session
C:\temp\FE_Model_Compare_HM_Versions.session
C:\temp\Solution_Solver_version_result_comparison.session
C:\temp\Result_Advanced_solver_result_comparison_HV_versions.session
