The Altair GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HyperWorks commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
The Model Identification Tool, known as HyperWorks, is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The HyperWorks operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using
the HgTrans GUI or via the HgTrans batch mode.
The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble
HyperWorks automations with minimal effort and maximum portability.
HyperWorks Verification and Validation Harness (HVVH) is a tool that can be used to verify and validate HyperWorks products. End users can use this tool to quickly evaluate the software quality, performance, reliability,
scalability, and robustness, and to gain more confidence in HyperWorks products.
The solver output results are used for further design verification and validation. The accuracy of the results as
processed, interpreted, and visualized by a post-processor is key. HyperView is used to post-process most of the solver(s) results. Use the Result tab to ensure that HyperView does not deprecate any result information after post-processing.
Uninstall HyperWorks is a tool to launch the HyperWorks uninstallation program. This program contains two options that allow you to either remove the originally installed
files, or remove all the files that resides in the installation directory.
Creates a new task, depending on the tab you are currently on.
Load Session
Loads a session file created manually or with the HVVH interface. The
selections/settings in the active tab are set per the session file.
Save New Session
Each HVVH session can be saved as a session file, which can be retrieved
later. You can load this session file into HVVH or run HVVH in batch
mode.
Append Session
Appends the number of sessions and can be used for batch mode job
submissions.
Exit
Closes the program
Edit
From the Edit menu, select Config File or Text
Editor.
Config File
Use the Config File option to create or edit the configuration
file.
Add HyperWorks version and path.
Invoke HVVH by invoking the batch file and then clicking Edit > Config File.
In the Version field, enter the HyperWorks
version.
In the Path field, click the file browser icon to select the
corresponding HyperWorks executable
path.
Click Add to populate the necessary clients in
the Version/Path Review table.
Tip:
Click Delete to delete all current
entries.
Click Save to save the configuration file.
You must restart HVVH for the new settings to take effect. For
example:
Version: 2020
Path:
C:\altair\2020
For the solver: The actual solver path
(based on the solver installation).
Add solver path.
From the Solver drop-down menu, select LsDyna or
Ansys.
In the Path field, click the file browser icon to select the solver file
path.
Define the solver executable version.
RadiossBlock or
OptiStruct.
version.
executable directory.
Text Editor
Use the Text Editor option to set the location of the text editor
(the editor that you want to use for viewing reports) on your PC. Click the file
browser icon to set the location.
Exit
Click Exit to close the module.
Help
Click Help from the menu bar to display the HVVH online
help.
